1992 honda accord needs a new motor
Old Oct 30, 2014 | 07:13 PM
Oreo-TeCk's Avatar
Default 1992 honda accord needs a new motor
First off I just want to say I searched but there was still open ended questions that weren't answered.
I need to swap a new motor in my cousins car which is a 92 accord SE and it currently has a f22a6 but its so hard to find a a6 so after researching to see what other options fit in the accord and f22b came up but says im goinna need to run the f22 exhaust manifold.. Is that all? Do I use the f22a6 intake manifold or the f23b??.. Any other info would be appreciated.. Thanks in advance.
Old Oct 30, 2014 | 07:33 PM
MIDNIGHTTUNER's Avatar
Default Re: 1992 honda accord needs a new motor
Is it not possible to rebuild the A6? In terms of the F22B, you should use the one that came with that engine. I don't know off the top of my hand all the interchangeability, but they should mostly be compatible. I think. While you're at it, H22 Swap? lol
Old Oct 30, 2014 | 08:17 PM
NerfGunner420's Avatar
you will also need the ecu for the f22b as well
Old Oct 30, 2014 | 08:19 PM
Oreo-TeCk's Avatar
I dont want to deal with the a6 not being able to be rebuilt after I take it all apart since the head has been resurfaced already in the past.. Especially that they ran the car hott for who knows how long that the headgasket is pretty bad.. Motor has 300xxx miles.. Would rather throw in a motor with lower miles and less ifs ands or buts.. The car is a daily for my little cousin so h22 would be over kill
Old Oct 31, 2014 | 04:35 AM
Fitz Williams's Avatar
10 Year Member
F22A and F22B have different exhaust and intake manifolds.
Old Oct 31, 2014 | 07:37 AM
wish i could pick up that a6 you are about to throw away.
Old Oct 31, 2014 | 11:49 AM
Oreo-TeCk's Avatar
Bump
Old Oct 31, 2014 | 03:18 PM
94 accord typeR's Avatar
Originally Posted by Oreo-TeCk
Bump
check out the FAQs at the top. sounds easy to me. just remember B1 is vtec and B2 is not. might be able to run B2 on A6 ecu?
cakooter
Mar 19, 2008 05:37 PM
hondaaccord90
Oct 23, 2007 11:16 AM
ebelp
Jun 17, 2003 03:36 AM
