Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
EPS problem.
Old Oct 30, 2014 | 05:25 PM
FG24's Avatar
Default EPS problem.
What's up guys I'm new here... Always browsed around the forums but never became a member.
Anyway. I'm having an issue with my power steering. The steering wheel is completely locked. The car was parked for about 5 months. I just put a swap in the car. But didn't touch the subframe at all. Checked all my connections and the #1 fuse under the hood all seems to be fine, but steering does not work whatsoever. Any help would be very appreciated.
I tried the search option and couldn't fine anything to benefit me in this issue.
Old Oct 30, 2014 | 05:56 PM
97emsedan's Avatar
Default Re: EPS problem.
Check your battery. If it is low, the EPS could be getting a bad signal, like the engine isn't running, hence the lock-up...
Got my info off Civinfo from the UK.
Old Oct 30, 2014 | 06:03 PM
FG24's Avatar
I just put a new battery in it this evening and it was doing the same thing.
No EPS light either which is strange.
Old Oct 30, 2014 | 06:07 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Check under-dash Fuse No. 4 (7.5A).
Old Oct 30, 2014 | 06:22 PM
FG24's Avatar
Checked fuse #4 and it's fine.
I'm confused as **** with this problem lol
Old Nov 1, 2014 | 05:40 AM
vladd's Avatar
What exactly is the issue? You can turn the steering wheel after starting the car, but it's not power-assisted? Did you plug in the rack wiring after the swap?
Or is the steering wheel locked with the car started, and you can't turn it at all?
Old Nov 1, 2014 | 07:53 AM
FG24's Avatar
Locked even when the car is started
Won't move at all. After trying every option I saw
Possible I called my local honda ... There's a warranty extension
On the eps module.
Which is what I'm assuming went bad
Old Nov 6, 2014 | 02:32 AM
TYPE-R#945's Avatar
Take it to the dealer, Eps issue we have a service bulletinf about and extended warranty will replace the control unit
Old Dec 11, 2014 | 08:16 AM
FG24's Avatar
I ended up replacing the whole rack/motor
deepsouthhybrid
Jan 25, 2012 01:11 PM
02_Si_FTW
11
May 8, 2009 02:28 AM
TurboEM1
Nov 27, 2005 08:48 AM
XxSOHCDriVerxX
Oct 1, 2003 06:24 AM
LB CRX
Nov 24, 2002 11:31 PM
