best piston ring gap placment........?
Old Nov 1, 2002 | 04:04 PM
non-VTEC's Avatar
Default best piston ring gap placment........?
should i just follow what the helms manual tells me for piston ring gap placment when installing new rings or is there a better way that alot of engine builders like to follow?
i guess for optimal cylinder pressure and oil control......?
i remmeber someone mentioning a better ring gap placment other than what the helms manual tells you..........but i dont remmeber where i saw it.....
any tips guys?
Old Nov 1, 2002 | 06:05 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: best piston ring gap placment........? (non-VTEC)
I like to check it about 2 inches from the deck, and then about 4 or 5 inches down from there.
Old Nov 1, 2002 | 06:09 PM
non-VTEC's Avatar
Default Re: best piston ring gap placment........? (Emerica)
i meant the placement of the ring gap when puting them on the ring lands of the piston..........what position is best to alignt the to rings, second rings and oil control rings..........
hope this makes sense......
Old Nov 1, 2002 | 07:25 PM
Evs-One's Avatar
Solbros Owns Me
oh, I see, the postioning of the rings compared to each other. Go with factory specs
Old Nov 1, 2002 | 08:28 PM
Farnsrocket's Avatar
didn't your rings come with instructions and their recommendation for gap placement?
Old Nov 2, 2002 | 12:12 AM
Flamenco-T's Avatar
Default Re: best piston ring gap placment........? (Farnsrocket)
go with OEM specs, I believe the first ring should face 11 O'clock
second is 7 O'clock
first oil ring should face either sided of the wrist pin
main opil ring should face 6 o'clock
last oil ring should face the opposite of the first oil ring
look at the piston with exhaust relief at 12 o'clock
double check the helms again !!!!!!!!!!!!!!!
stan
Old Nov 2, 2002 | 06:56 AM
PhatOptimo's Avatar
Default Re: best piston ring gap placment........? (Britney Spears)
Staging rings is gay...if you think they are not gonna turn and move anyways, thats crazy talk. Its not like they wont spin anyways.
Umm ok that just like saying honing the cyl walls is gay when you install new rings. Just plain ignant! There is a reason to off set the rings and I do it when I build engines. You can build yours however you fell but misleading someone is pile of ****. Your full of BS just so happens that is you SN initals. hahaha
Old Nov 2, 2002 | 07:47 AM
b19coupe's Avatar
Default Re: best piston ring gap placment........? (Flamenco-T)
There is more than one o.k. way to place the rings. Just make sure that none of the ring gaps are directly on the thrust area of the pistons : the front and rear of the engine.
Paegelow
May 22, 2010 08:10 AM
averyvm
Apr 5, 2007 07:25 PM
Speedz
Nov 15, 2006 10:04 AM
Doggett3
Feb 1, 2006 01:46 PM
