Maintenance help ?
Old Oct 28, 2014 | 07:41 PM
RickyDayz's Avatar
Post Maintenance help ?
I just bought a 1995 Honda Civic coupe, anyone know what maintenance needs to be done at 182K miles... the previous owner said he didn't do any changes to the car.
Old Oct 29, 2014 | 05:56 PM
NotARaCist's Avatar
I never narc'd on nobody!
Default Re: Maintenance help ?
FAQ sticky.
Old Oct 29, 2014 | 06:11 PM
joey1320's Avatar
With 182k miles, the car will pretty much need everything...
Old Oct 30, 2014 | 02:26 AM
HondaPartsHero's Avatar
Technical Hero
In a nutshell if you're willing to dish it out
-full tune up (spark plugs, plug wires, cap, rotor), check ignition timing
-fuel filter
-drive belts
-timing belt/water pump
-check for any oil leaks and repair (valve cover gasket, front main seal, distributor O ring)
-if manual transmission, fluid drain and fill
-coolant flush
-brake fluid replacement
-power steering fluid replacement (if applicable)
This is just engine/trans area type maintenance, not including brakes, suspension, etc
Check the FAQ above for repair guides
supergtp1
Jun 2, 2014 10:22 PM
RNPoo7
Aug 21, 2005 02:05 PM
MachAF
Jul 22, 2005 01:35 PM
Ms.JDMdb8
Jul 9, 2005 06:34 AM
Campee
Apr 2, 2003 09:32 AM
