Ordered a new rear wheel hub and got this
From: Pensacola, FL and every Court House in Louisiana
This is a SKF BR930127 rear hub assembly that everywhere I have searched says is for a civic/integra rear disk setup. I remember there were a couple bolts I could have removed from trailing arm to swap drum to disk but I went ahead and swapped the entire trailing arm. I dont remember the bolt pattern being in a triangular shape. Any help would be appreciated. I am currently out of town so unable to crawl under car and look myself.
What year, make, model, trim, and any mods if its not stock?
That is the bare minimum rules for tech threads.
As far as I know at this point, I need to look up a 1978 Honda CVCC rear hub assembly.
Apologies. It is a 94 Civic VX- turbo GSR, 98 ex front knuckles with ITR calipers and cooper rotors, not that any of that is of importance. The rear is integra rear disc swap off a 98.
I tend to agree with 94EG8, every civic and integra rear hub I looked up didn't have any bolt flanges, just the hub and ABS ring.
I didn't have a year Integra to look at so was just generally looking and they all pretty much looked of the same style with no back side bolt flange. The spindle/axle nut is what kept it together and preloaded the bearings. As can be seen here on item #2:
Just a misbox, that's not even a rear hub... It has drive splines.
The newer ones (06+) are unitary like that iirc, but that is not one of them.
standbackimapro
Jul 16, 2007 06:47 AM
PearlWhiteAccord
May 9, 2005 09:20 AM
