Location of VSS on 2014 CR-V?
Installing meter for a cab, need to know where I can find VSS.
Normally get info like that off Mitchell On Demand, but very confusing on the 2014, may be data only and the meter only has pos.(+) or neg.(-) input for VSS. 94
I don't think there is a VSS, I think it uses the output speed sensor for vehicle speed. If that is the case you will need to divide the signal by the differential ratio to get true vehicle speed.
(Use the 2011-2012 MY in your service info for more details)
Yea got it figured out, had to install a pulse generator, easy wire up to the OBD diag. port. 94
