crank no start need help. tried everything!!!!!!
Old Oct 27, 2014 | 10:22 PM
attia's Avatar
Default crank no start need help. tried everything!!!!!!
ohk so here is the thing.......i have a 96 civic with a jump harness to a p06 {obd1}.ive replaced my main relay, ecu, fuel filter,fuel pump, fuses, checked for power in the relay and fuel pump and i do have power. i just went to the picknpull and got a dizzy replaced my ignition coil. still won't start NEEEEEED HELP
Old Oct 29, 2014 | 04:18 PM
97emsedan's Avatar
Default Re: crank no start need help. tried everything!!!!!!
Did you purge your fuel rail? You might have a vapour lock in the rail or lines.
Old Oct 30, 2014 | 04:35 AM
DaveSi677's Avatar
Moved this to the correct section as you might get more answers...
Old Oct 30, 2014 | 04:41 AM
Former User's Avatar
  1. Tell us what engine you have the P06 connected to.
  2. Check whether the fuel pump primes.
  3. Check for spark at all 4 spark plugs.
Leo Bracamonte
Feb 4, 2015 04:05 AM
01integra_gsr
Dec 10, 2011 11:08 AM
dan617
10
Jan 31, 2009 02:10 PM
bimmeracer
Jul 16, 2008 06:12 PM
vietjdmboi
Mar 8, 2005 06:33 PM
