93 Del Sol Si wet floor
I drive a 93 Del Sol Si
209k on the body
D16A Motor swap
170k on the motor
I was cleaning out my blower motor today, when i pulled back the carpet the floor was soaked on the passenger side under the carpet. So i checked the drivers side and it was wet as-well but not as wet. Anyone else had this problem with a 92-95 Civic or DelSol? I cant seem to trace the leak theirs no water on the firewall just the bottom of the floor. I know its not coming from the door or roof any info?
Ive heard that civic of this generation have this problem and its the drain holes under the cowl, but were my water is that doesn't add up.
I removed the windshield cowl to get a better look but that offered no insight. It goes straight into the blower motor hole but that doesn't explain water on both sides.There are drain holes on either side of this drain trench.
Blower motor hole \/
Wet Floor \/
Underneath the cowl \/
Attachment 381905
Directions for common leak \/
209k on the body
D16A Motor swap
170k on the motor
Wet Floor \/
Attachment 381905
Get a friend with a hose. If it's a fire hose, even better. If not, a garden hose will work. Flip yourself upside down, get your head up in there, and get comfortable. Have your friend spray your car down while you look and listen for drips and leaks. Also, inspect the wiring grommets that protect the harnesses and hoses that come through the firewall, make sure they aren't damaged and allowing water through. While you're doing that, give the liquid a quick sniff - is it water, or is it coolant?
I inspected the AC drain as-well and it seems fine and blockage free.
Im no stranger to finding leaks, my sol has had Targa leaks, windshield leaks, sail panel leaks, and taillight leaks all of which are now fixed. I guess its time to do it again.
As soon as possible i will inspect the grommets and see if there is any problems there. Then spray it down and see what happens. Would it be a bad idea to do this with the cowl off the car? I dont want to make anything worse. I am afraid water getting in the little tray underneath the windshield would work its way in and stay in there (the little one not the big one). Then again that maybe the problem.
Before all is said and done I plan on making a little cover for the blower motor hole so water cannot run directly into it as-well.
del sol's leak a lot from the top but im sure you'd be able to tell if it was the top very easily, best bet is to get in there and spray around and see what causes it, and if it happens when it rains then it leaks thru if it randomly appears when it doesn't rain your leaking some kind of fluid could be from a/c wouldn't hurt to get it serviced or checked out, most places check for free at least up here for a/c
Resurrecting my own thread to bring a conclusion to the story.
The water was indeed coming from a improperly sealed windshield. This trapped water that created rust and subsequently a hole that let water into the vehicle. None of this was visible untill the windshield was pulled. With the windshield removed i ground away the rust, sealed the holes. Had a new wind shield professionally installed (safe-lite) and i haven't had a wet floor on either side since.
del_sol_sir
Mar 5, 2009 04:05 PM
sam385
Jan 29, 2007 05:20 PM
dreamvision500
May 27, 2004 08:36 AM
wuhungsixxx
Jun 21, 2001 12:55 AM
