Crome vs. Hondata on a B16B in a CRX
Old Oct 27, 2014 | 04:57 PM
Haws's Avatar
Default Crome vs. Hondata on a B16B in a CRX
Hey guys!
So I'm basically wondering what to go with, Chrome or Hondata. Hondata is around $600 and Chrome is around $100. I've been searching and it looks like Hondata is more "User Friendly" atleast for the tuner. Also, someone recently told me Hondata isn't worth it if I'm not going to go turbo. So pretty much, is Hondata worth it or should i just go with Chrome?
Thanks!
Old Oct 27, 2014 | 05:11 PM
F22Master's Avatar
Default Re: Chrome vs. Hondata on a B16B in a CRX
Are you going to be tuning it yourself, or taking it to someone?
Old Oct 28, 2014 | 02:39 AM
Haws's Avatar
Yes, Id like to tune it by myself.
Old Oct 28, 2014 | 03:02 AM
Freemananana's Avatar
A mod list would be great to determine how much tuning you will really need to do.
If it is just I/H/E on a B16B, then chrome would probably be best since you won't really be able to tune in much NA on the street.
Old Oct 28, 2014 | 07:13 AM
v4lu3s's Avatar
RTFM
Its a toss up, when CROME works it works well. I used it for a while on an obd1 converted high compression d16a6 and it had good driveability but would NEVER idle evenly. I finally got mad and got a hondata s300 which works very well, idles perfect immediately and is less gimmicky. If this was not a daily driver i would probably still be using CROME, but driving it 5-7 days a week i want it not being gimmicky.
Old Oct 28, 2014 | 11:48 AM
4drEF's Avatar
Keyboard Humorist
Hondata S100 is just under $200 and seems like it will do what you need for a non-turbo setup.
Old Oct 28, 2014 | 06:05 PM
Muckman's Avatar
Moderator in Chief
Crome is fine if you don't need the advanced features. But you need to realize Hondata is hardware and software vs Crome is just the software. With Crome you will need equipment to burn chips and datalog unless you spend another $250 for the Moates Demon. If you go that route you might as well get Neptune.
Old Oct 29, 2014 | 04:16 AM
boosted k20's Avatar
i have been using crome and tuned a lot of cars on it for about the past 8 years. It works good and i never really had an issue with it. i use crome gold as it runs the cars better than the regular crome map. I now have hondata S300 in my car and it i would not go back to crome on my personal car. Hondata is better all around. Save up and get hondata
Old Oct 29, 2014 | 06:49 AM
PyroProblem's Avatar
Consider Neptune as well. Many satisifed users including myself.
Old Oct 29, 2014 | 07:46 AM
Haws's Avatar
I think im going to go with hondata s300. Crome would be a good choice as well.
Old Oct 29, 2014 | 05:47 PM
VegasInvasion's Avatar
I'm Huge In Japan
Crome is not a good choice. It never was, and never will be. I probably have more tuning (and published work) on Crome than anyone else here, I do not and will not ever recommend it if you have another option.
FWIW, I preferred Neptune as a beginner, Hondata's UI has a sporadic navigation. But either will do the job.
Old Oct 31, 2014 | 06:14 AM
motoxxxman's Avatar
Default Re: Crome vs. Hondata on a B16B in a CRX
I'm with vegasinvasion here. and note what muckman said. crome software is $100+. but then you need a chip burner and datalogger, and emulator to make it a million times easier for live-tuning, which is another $300+ just for the hardware.
get hondata, much better dollar for dollar.
the only time I ever recommend anyone ever using crome is if they'll be paying a reputable tuner with several years of experience with crome, simply because it'll be lower cost in the end for the customer. and only for setups under 300hp
May 13, 2009 06:57 PM
-iLLuZioN-B18C1
Oct 15, 2004 07:20 PM
7rrivera7
Nov 6, 2002 08:35 AM
