Tech help w/ tuning a built all-motor H22A
Old Nov 1, 2002 | 03:26 PM
All-MotorSports's Avatar
Default Tech help w/ tuning a built all-motor H22A
In about 2 weeks we should be firing up my wife's built H22A w/ 11:1 compression, portflow head, and Jun cams and we need some tech help on what we should set the fuel settings on her V-AFC until we can get it broken in and then to a dyno w/ a wideband O2 sensor. We're running stock ecu, fuel pump, injectors, etc. so we're going to have to make the corrections, at least temporarily, utilizing the V-AFC. My initial plan is to set the vtec crossover point @ 6,000, increase fuel 5 percent over stock maps across the entire power band, use 1 heat range colder plugs, and retard the ignition timing to around 13-14 degrees to help prevent detonation due to poor air:fuel ratio. Any ideas or suggestions would be greatly appreciated.
Old Nov 1, 2002 | 05:10 PM
d-wreck's Avatar
Default Re: Tech help w/ tuning a built all-motor H22A (All-MotorSports)
um set it to stock and do the honda factory break in procedures
then when its broke in take it to a dyno
derek
92SR4WS
Engine Management and Tuning
10
Jul 27, 2009 12:08 PM
MugenAccordSedan
May 5, 2004 08:51 PM
jayisnameless
Jan 28, 2004 03:22 AM
4gen
Mar 9, 2003 05:09 AM
All-MotorSports
Nov 3, 2002 08:17 AM
