V-bands and engine movement?
Old Oct 26, 2014 | 02:19 PM
siblues's Avatar
Default V-bands and engine movement?
I just wanted to ask in here since you guys are the ones who actually make the parts.How do V-bands hold up to engine movement?I know most of the setups I have seen the intercooler is usually bolted down making it stationary while the engine moves and I know alot of people use solid mounts which would probably take care of 90-95 percent of the movement?
Old Oct 28, 2014 | 12:41 AM
para pat's Avatar
Default Re: V-bands and engine movement?
A v-band is a rigid connection. For all intents and purposes, it can just be assumed there is no coupler where a v-band connection is. You still need to have flex somewhere in the system - even with solid motor mounts. I use either silicone or a Pegasus clamp on one end and a v-band on the other.
Old Oct 28, 2014 | 05:41 AM
weiRtech's Avatar
OG Fabricator
vanjen clamps are a better option than vband imo.
Old Oct 28, 2014 | 04:54 PM
siblues's Avatar
I agree but when you start needed 5 clamps it really isnt cost effective for a guy like me.I spoke to someone on here and he also agreed that there needs to be a flexible joint in the system and that was my reasoning behind this thread.Thanks alot guys
Old Oct 29, 2014 | 04:27 AM
redboost10's Avatar
4 vanjen clamps here and engine is mounted solid with a block plate.
Old Oct 29, 2014 | 04:35 AM
that-guy's Avatar
I used 1 v-band at the discharge of the turbo, and a bracket off of the discharge pipe to the motor, making that pipe move with the motor, as my setup is with delrin mounts, then the pipe going from the discharge pipe to the IC is a silicone coupler
Old Oct 30, 2014 | 07:41 PM
siblues's Avatar
Yeah I was figuring most of you guys were going to be running solid mounts.I decided to just keep the hump hoses until I start having issues with them and then I guess 3-400 bucks in vanjens would be the best choice.
Suare
Feb 13, 2012 06:03 PM
Kryptonite
Feb 20, 2006 11:22 AM
turbotime
10
Sep 26, 2005 11:21 PM
vettman
Jul 20, 2005 12:46 PM
stevescivic
Jan 10, 2005 09:16 PM
