b16a2 compression question
Old Oct 26, 2014 | 08:24 AM
poppin-vtec's Avatar
Default b16a2 compression question
Hi guys im new to Honda-tech and I just have a question about b16a2. So im in the works of buying an 99 Si. The guy did a compression test and it came out 165 170. I don't know how much it should be running so before I buy it i wanted to ask you guys if that sounds about right. If not how much should it be running ?
Old Oct 26, 2014 | 09:32 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: b16a2 compression question
It's older and will have lower compression numbers anyways. That seems fine as long as they were pretty close together. You only listed 2 numbers so I assume they were all within that range which is OK for a higher mileage engine. There are multiple things that could affect a compression test though like throttle plate open or not, warm or cold engine, inaccurate gauge, etc...
EG6 Love
Feb 15, 2008 05:06 PM
itsmebeaner1987
Oct 31, 2004 11:54 AM
98cwtypeR
Jun 4, 2003 10:29 PM
FrankEXsteiN
Dec 23, 2002 04:46 AM
SloEG
Jul 28, 2002 06:13 AM
