Looking for tuning advice turbo b18
Old Oct 24, 2014 | 01:39 PM
Pullig's Avatar
Default Looking for tuning advice turbo b18
Hey all looking for some advice to make sure I'm heading in the correct direction
I'm tuning myself and need help.
The setup
B18c 81mm cp Pistons flat top 9.8-10 compression
4.5 ptw
Itr head with itr cams stock cam gears retarded 1-2 degrees both sides
Due to decked block and head
93 octane
Had to fully advance dizzy to get my 16deg line up with Ecu
Turbo setup ram horn turbonetics 6162
44 tial gate--5lb spring spiking to 8lbs around 8k rpm
Ngk Bkr7
Afr super rich. 11.6-12 low cam and high
I have innovate egt monitoring cyl 3. Egt around 1070-1100 at wot. 800 low speed cruise.
80mph slightly higher than wot
Now to the issue at hand. I started out with a conservative map Atleast I thought around 1 degree per psi retard
Did a few pulls read sparkplugs read hot according to ground strap. Line near threads. But only getting 2-3 threads of color change
They read rich too
The plugs are showing pepper and shiny aluminum. Which is bad. No destruction of plugs or anything melting
Continued to pull 2 degrees at a time changing plugs each time and progressively got better results
I can see my timing line creep up to the bend on the strap
The timing just seems excessively low to me
The car runs good pulls good. Just seemed weird to me.
I've read where retarded cam timing can cause higher cylinder pressure. Could that be the issue ?
Old Oct 24, 2014 | 01:42 PM
Pullig's Avatar
Default Re: Looking for tuning advice turbo b18
High cam.... Also I've checked to make sure there were no other corrections to change table timing.
Both my table and final timing numbers match exactly
Old Oct 24, 2014 | 03:46 PM
boosted94gsr's Avatar
Your timing numbers look extremely conservative. Did you disable the rpm based ignition advance table? The one that adds a set amount of timing on top of table timing at all times based on rpm. If so that needs to be added back into you timing table, witch I doesn't look like it is.
Maybe you have a mechanical timing issue? Did you lock the ignition timing when you set base timing? And how exactly did you retard the cam timing with stock cam gears?
On my setup I had to go with 8 heat range plugs even tho I'm not making a whole lot of power. With 7s I would get detonation even with conservative timing and fuel numbers.
Old Oct 24, 2014 | 04:20 PM
Pullig's Avatar
Well I had the block decked and head decked. In doing so it mechanically retarded my cam timing. I will prolly end up having to get adjustable cam gears to get it back In spec. But for these purposes it shouldn't hurt anything.
I didn't disable ignition adjustment because when data logging my table timing and final numbers always matched throughout boost.
I did use the software to lock ign at 16 and use my timing light to line up with tdc since I'm using the adjustable timing light
Yeah I figured I need 8s. So I got those in now. And I'll do more pulls check plugs. It just sucks *** cause the 7s wee so cheap and I could cut them in half every few pulls. Now with the oridium 8s. I can't do that so many times.
I'm hoping that I'm really close now since I had the timing line near the bend of the 7. So I pulled another degree or so and now have 8s. And will see
I just wanted to make sure I'm headed in the right direction. .
Old Oct 24, 2014 | 04:34 PM
Ya it sucks that NGK doesn't make cheap copper resistor type plug in an 8 heat range, but i run the NGK 8 copper non resistor plugs with NGK plug wires and don't have any interference issues with Neptune or data logging. Plus they are only like $2 a piece. I have heard of people having problems with non resistor plugs and hondata tho.
As far as I know the rpm based ignition table is always running in the backround unless you disable it. Hondata just probably doesn't show it in the final timing number. I know Neptune shows it in the actual timing value when I log it, because actual timing will be about 9 degrees higher then table timing at 7k rpm.
Old Oct 24, 2014 | 04:42 PM
Pullig's Avatar
Well I'm running ECTUNE. I figured you needed resistor plugs regardless of platform. I'll look into those and I guess try them out. I'll dig lil more and see what I can find but I've not disabled anything regarding that.
Old Oct 25, 2014 | 05:29 PM
Pullig's Avatar
Anybody else got advice to share.
Old Oct 28, 2014 | 03:58 AM
boosted k20's Avatar
take the car to the dyno to dial in the ignition timing. Your timing seems very low.
protopro88
Feb 17, 2012 09:42 PM
Listerofsmeg
Jan 16, 2012 06:50 AM
gsrekrevs210k
19
Feb 27, 2011 09:54 PM
thehatchninja
Jun 4, 2005 08:28 PM
JDM 007
Sep 28, 2002 01:38 AM
