Why so lean on a cold start?
Old Oct 24, 2014 | 12:02 AM
mr_munro's Avatar
Default Why so lean on a cold start?
Are these AFRs normal for a cold start?
Stock ITR base map for a STOCK ITR (aussie 11:1 CR) with I/H/E
not sure why columns 7 and over have light up when i didnt take the car over 1600rpm, in my drive way (touched the throttle slightly)....
originally pulled codes 13 and 16 - so disabled fuel injector error and barometeric pressure sensor. codes gone, will this effect the car's driveability ?
Old Oct 24, 2014 | 12:15 AM
mr_munro's Avatar
Default Re: Why so lean on a cold start?
Am i suppose to disable closed loop to get more accurate reading and is it safe running the car till warm that lean? Car smells a bit rich when i turn off however. I want to take it for a drive to make sure i pull no codes anywhere
Old Oct 24, 2014 | 04:43 AM
joakwin's Avatar
Hondata s300 Programmable ECU Guide
http://www.hondata.com/help/smanager...mpensation.htm
Old Oct 24, 2014 | 08:51 AM
spAdam's Avatar
Loved
Community Favorite
You probably need to go after your temp compensations and your post-start trim/decay.
Columns 7-9 were probably highlighted during/just after cranking at a point where there was not much vacuum built up yet. The logger doesn't know the difference, it's just reporting whatever you tell it to. There's no other reason to be that low on the rpm scale, especially if cold.
Old Oct 24, 2014 | 11:01 AM
98vtec's Avatar
moderator emeritus
basemap.....
Old Oct 25, 2014 | 02:59 PM
mr_munro's Avatar
Forgot to mention I not using wideband yet..
Old Oct 25, 2014 | 06:42 PM
98vtec's Avatar
moderator emeritus
so you arent running a wideband yet you are viewing "AFR". Am I missing something here?
Old Oct 25, 2014 | 11:59 PM
mr_munro's Avatar
Yea you are right
basically my tuner has the wideband which he puts into the exhaust tailpipe so he will read off that.
For now I am just checking the car will be safe to drive for the purpose of code checking, so none appear on the dyno.
No hard driving, just need to make sure VTEC enages etc and throws no codes.
Old Oct 26, 2014 | 03:03 AM
spAdam's Avatar
Loved
Community Favorite
No wideband means that those numbers mean nothing though. You have some reading to do.
Old Oct 26, 2014 | 03:57 PM
VegasInvasion's Avatar
I'm Huge In Japan
If you don't have a cat then AFRs from the tail pipe can still be accurate.
But you have to realize all O2 sensors take time to warm up before they start reading anything other than lean. Your cold start might be normal. You can't use those numbers unless your O2 is already heated up on its own circuit. Wideband or not.
Old Oct 26, 2014 | 04:24 PM
spAdam's Avatar
Loved
Community Favorite
He's not looking at tailpipe as far as I can tell though, just logging straight from the ecu.
That's a good point, but wouldn't a narrowband show rich when cold since the output is inverted compared to a wideband? I guess it depends on how you have it declared in the settings.
Eg.ls.turbo
Engine Management and Tuning
Sep 15, 2014 09:30 PM
thewrai6th
Jun 11, 2007 09:35 AM
the.hamburglar
May 2, 2006 09:27 AM
Project_Civic
Apr 1, 2006 07:19 AM
LoseRPunKx182
Aug 2, 2005 08:46 AM
