1991 Hatch
Old Oct 23, 2014 | 03:01 PM
fannin614's Avatar
Default 1991 Hatch
I have posted on here before abt a build. Now im kinda stuck. So i am gonna ask suggestions yet again. I have a d15 that should need replaced. Cant get the b18 tht i wanted so gotta down size a bit. So my very important question is, what will work in the car without mods?. Just drop and drive...keep in mind i am wanting to boost. Not looking for a 450hp car but want some power
Old Oct 23, 2014 | 06:27 PM
Evo9GSR's Avatar
Default Re: 1991 Hatch
What do you mean what will work? If the swap is done correctly everything will work.
Old Oct 24, 2014 | 03:02 AM
Freemananana's Avatar
He said drop in and drive.
Any D-series engine will drop in, bolt up to your intake, exhaust, and transmission and run.
Old Oct 24, 2014 | 02:39 PM
fannin614's Avatar
Thank you. D17 it is.
Old Oct 24, 2014 | 03:35 PM
1991_crxsi's Avatar
You will still have some wiring to do.
Old Oct 26, 2014 | 04:52 PM
fannin614's Avatar
But it shouldnt be too bad considering i am staying the same ecu right?
Old Oct 26, 2014 | 07:11 PM
M3THTICAL(EF)'s Avatar
Just stick with a d16a6 or Sohc ZC, even a d15b7!
Old Oct 27, 2014 | 04:31 PM
fannin614's Avatar
Ok. Last question which out of the d16zc d15b7 and the d16a6 would be best and tuned right boosted, how much power am i looking at
Old Oct 27, 2014 | 04:32 PM
fannin614's Avatar
Ppg orange is gonna be the color too if any other suggestions with paint let me know
Old Oct 27, 2014 | 11:38 PM
Sohc Zc - 118 hp at the crank
D16a6 - 108 hp at the crank
D15b7 - 102 hp at the crank
From researching in the past when i was thinking of boosting, the a6 bottom end stock could handle around 180-200 hp.
Old Oct 28, 2014 | 05:50 PM
fannin614's Avatar
So a6 would be better or the zc. Looks like it produces more stock and if u boosted could it gain a little more
Old Oct 28, 2014 | 06:27 PM
Id go with the Zc if you can get it for cheap.
Old Oct 29, 2014 | 02:54 PM
fannin614's Avatar
Appreciate all the help guys. New to it so away i go to start my build. Will try and keep interest folks updated on it. Thanks again. Best regards
Milesd15
May 13, 2013 09:38 AM
d15b2_ed6
Nov 22, 2006 07:09 PM
nitrousrush
May 30, 2005 06:31 PM
G60
13
Mar 4, 2005 06:43 AM
slipperyduck
Apr 4, 2004 09:19 PM
