Clanging sound by right side wheel
Old Oct 22, 2014 | 01:26 PM
civicboy420's Avatar
Default Clanging sound by right side wheel
Hey guys I just started having a loud clanging sound around my front end. I know I have a bad wheel bearing needing to be replaced, and I just replaced my passenger side axle. It makes a loud clicking sound, but only when I left off the gas or coming to a stop holding in the clutch. The sound stops when I give it gas or when I hold the brake. When I go slow the clicks go slow. I keep thinking my front end is going to fall apart when I'm driving. Any help appreciated.
Old Oct 22, 2014 | 02:55 PM
4drEF's Avatar
Keyboard Humorist
Default Re: Clanging sound by right side wheel
How bad is the bad wheel bearing?
I would start there.
When you are coming to a stop in gear, the axle provides some force that is probably helping the hub not flop around in the wheel bearing. That might be why you hear sounds when you do the same, but out of gear.
Same with the brake. The caliper might be holding the disc+hub just enough to keep if from making noise.
Old Oct 22, 2014 | 03:01 PM
So it shouldn't be in the transmission?
Old Oct 22, 2014 | 04:10 PM
Tyson's Avatar
i dunno, check the lugnuts. balljoint nuts.
shrug.
how does "i have a noise, someone help" expect to be answered over the internet???
Old Oct 22, 2014 | 04:24 PM
I don't know it's just very frustrating
Old Oct 22, 2014 | 04:40 PM
Tyson's Avatar
how about taking your car to a shop?
Old Oct 22, 2014 | 04:57 PM
Because they charge 80$ an hour which I don't have at the moment.
Old Oct 23, 2014 | 12:47 PM
4drEF's Avatar
Keyboard Humorist
Maybe inspect under the car and see if you have one of these stuck under there
Old Oct 24, 2014 | 01:50 PM
David_S's Avatar
Most shops will give you a written estimate though. In that estimate it will state what parts they plan to replace.
"Oh its gonna cost that much! I am going to have to wait till next pay check."
Drive off and go replace what the estimate says.
Old Oct 24, 2014 | 07:38 PM
No monkey under the car lol. I figured out the problem, i lost a lug nut and the rest were loosened good to go now.
Old Oct 24, 2014 | 08:14 PM
Tyson's Avatar
Do I win a prize? Your welcome.
Frozen E
Jun 12, 2022 09:23 PM
jkalex05
Nov 23, 2009 06:52 PM
Schmitey
Jun 23, 2008 09:46 PM
Josh.
14
May 30, 2005 09:47 PM
Monkey Fing a Coconut
Oct 24, 2003 10:45 PM
