what the best head for my D15B2 ????!
So I have a d15b2 automatic 88 crx nd I was wondering what would be a good head for it because my old head had bad valve seals so please help me out on finding the head
Thanks
Thanks
^^^What he said.
OR
Just fix the Bad Valve seals easy to do if the cylinder head is already off the engine.
OR
i would personally just swap the whole engine out if possible/ looking for vtec or id just get a new d15b2, they are a cheap and fuel efficient engine
Do not look for vtec.
You won't have much luck finding a suitable ECU that can run vtec and you automatic transmission.
MOE has a great idea which is probably your best option.
I suggest you do some work on your head and just get it working right.
Stick with another B2 head or an A6 head would be good options if you have to replace the whole head.
If you want a little more power, check into finding a PS9 ECU (somewhat a of rare find) and doing a DPFI to MPFI conversion.
I have a y8 head nd waiting to get a p28 autos ecu and y8 intake and the new engine harness then it would run right ?
Or what should I do to it ?
I just want it to get up when some one pull's up on the side of me say let's run it cuz were I live there all kinds of Hondas so any help would me helpful
Thanks Anthony
Thanks Anthony
bigsnorlax
May 7, 2009 11:08 AM
