Spluttering/chugging/struggling at low revs
Old Oct 21, 2014 | 05:22 PM
L14m_93's Avatar
Default Spluttering/chugging/struggling at low revs
Hi guys I've tried to search for this but all seem to differ fr my problem slightly :/
I've just done another engine swap I swapped out my b16a block for a b16a2 block and bolted all my parts onto the new block hooked everything up and plugged everything in car starts and idles at 2,500 cold then won't go below 2,000 when warmed up... Also when I'm driving along at low revs and put the accelerator down the car "chuggs" along as if its struggling to build up the revs and its actually like a violent struggle you get shoved back and forward in your seat! but then its like when it gets to around 4,700-5,000 it pulls strongly then when it engages in vtec it pulls as it should any ideas how I can solve this?? Code 10 (air) and code 20 (eld) are present but they were there with the old engine and this problem wasn't there
Old Oct 23, 2014 | 03:25 AM
L14m_93's Avatar
Default Re: Spluttering/chugging/struggling at low revs
Bump!!??
Old Oct 23, 2014 | 04:20 PM
OMG's Avatar
OMG
can you post a video
Old Oct 24, 2014 | 03:26 PM
bspeed's Avatar
I have seen this at cruise around 2800-3500 rpm if the o2 is on its way out, it can't meter the fuel and causes the stumble.
Just one of the reasons that this can happen.
eg123456
Aug 28, 2014 06:06 PM
Tyte-S
Apr 26, 2010 09:25 PM
SandstormGT
10
Nov 18, 2007 08:53 AM
Slow_import
Mar 23, 2006 12:47 PM
DarkSol97
Sep 4, 2003 11:05 AM
