Wire Harness plug identification.
I bought a em2 with a mostly tucked wire harness. The fusebox was moved into the cabin where the glove box goes. I have a few plugs that were zip tied to the harness next to the fuse box that I cant seem to identify. I tried to get pictures of both sides of the plugs to help with identifying them. Any help would be greatly appreciated. I cant find a decent wiring diagram either so im asking for any help I can get.
Thank you for your time
1. First and second pictures: 2P gray connector with Lt Grn/Blk and Blk wires is for PSP switch.
2. Third and fourth pictures: 2P orange connector looks to be for right front wheel sensor. (Orange connectors are ABS related).
3. Fifth and sixth pictures: 4P gray connector looks to be for secondary HO2S.
4. Seventh and eight pictures: 12P Black connector is for the cruise control actuator.
5. I will see if I can find the last two connectors.
1. For the 2P gray connector with Grn/Red and Blk wires, see if the the brake fluid level switch is plugged in.
2. Last pictures: 5P gray connector is for windshield wiper motor.
