84.50 b16 with eagle rods, using oil suirters?
Old Oct 18, 2014 | 06:34 PM
RACEPAK's Avatar
Default 84.50 b16 with eagle rods, using oil suirters?
hey guys,
just wondering...
do i need to remove the oil squirters with a 84.50 b16 with stock length rods,
thanks
Old Oct 19, 2014 | 10:27 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 84.50 b16 with eagle rods, using oil suirters?
The rods aren't the problem, the pistons usually are. You can work around the problem by bending, twisting, and/or shaving as necessary.
Old Oct 19, 2014 | 11:31 AM
NotARaCist's Avatar
I never narc'd on nobody!
If you're using Eagle rods, it's a safe assumption you're using aftermarket forged pistons. If that's correct, then you don't need the oil squirters.
Old Oct 20, 2014 | 07:37 PM
wantboost's Avatar
Who is Mr Robot?
The squirters still help regardless if the internals are forged or cast. I try to keep squirters whenever I can.
The biggest issue you'll run into is the pistons probably aren't clearanced for the squirters.
Look at the stock pistons and replicate the clearance on the forged pistons. I've seen people do it with a dremel tool. Just break any sharp edges, you won't effect the strength of the piston.
Flixz27
Jun 22, 2012 11:06 AM
flatblackDA
Nov 29, 2005 07:06 AM
stevomc51284
May 10, 2005 12:50 PM
boostin4door
10
Feb 25, 2005 02:02 PM
ImportHatch
May 22, 2002 08:24 AM
