98 honda civic help with questions
Old Oct 18, 2014 | 11:51 AM
davidzhou4893's Avatar
Default 98 honda civic help with questions
is 1k rpm normal at idle?
i have a misfire on all cylinder and random misfire if distributor was turned a few times would it be the cause of the misfire?
also have a bad cat code p0420
car also overheats within 2hour drive
Old Oct 18, 2014 | 05:47 PM
Exgie's Avatar
Default Re: 98 honda civic help with questions
1K sounds fast for idle.
What do you mean turned the dist? It probably not cause a misfire.
Ok, what is wrong with the cat?
Ok, it overheats there could be any number of reasons for it to overheat. Tstat, radiator issue, clog in the system, leaks, low fluid, an engine working harder than it was designed to, air to the radiator, missing air guides, front end damage.
Old Oct 18, 2014 | 07:41 PM
Took off the distributor and turned the pawl http://bp2.blogger.com/_YN8iBBL6lrw/.../s320/dist.gif
Old Oct 19, 2014 | 03:23 AM
HondaPartsHero's Avatar
Technical Hero
Last tune up?
Check compression?
Post all check engine lights.
Old Oct 19, 2014 | 10:04 AM
Last tune up not sure brought it last year, I changed spark plugs, plug wires, cap and rotor, fuel filter, fuel pump, only codes I have are misfire and bad cat, p0300 p0301 p0302 p0303 p0304 p0420
Old Oct 19, 2014 | 11:19 AM
NotARaCist's Avatar
I never narc'd on nobody!
Reset your ECU. Do the codes come back? What trim is your car?
Do a compression test.
XRACER63
Jan 22, 2018 04:37 PM
ZSpoerke
Jun 18, 2015 03:36 PM
thspittingllama
Dec 19, 2012 06:04 AM
Hondaiii3
12
Sep 19, 2011 01:23 AM
snmont01
Honda Civic (2001 - 2005)
Jul 7, 2011 04:31 AM
