2000 civic ex front wheel bearing issue
Old Oct 16, 2014 | 04:08 PM
skaternak's Avatar
Default 2000 civic ex front wheel bearing issue
I just replaced my front wheel bearings on my 2 door ex. one of the circlips came off one of them. so my tire was loose. i havent driven it since then. I checked for freeplay and it moves a little (no circlip in there). Is there suppose to be freeplay if the circlip is not in there, or is that normal? because i'm not sure if the bearing went bad when it fell off. I have spun the wheel (took the whole knuckle off) and there is no noise. but when i drove it, it make a slight rubbing/squeeking sound about every 2 seconds. Any help is apreciated.
Old Oct 16, 2014 | 04:15 PM
Former User's Avatar
Default Re: 2000 civic ex front wheel bearing issue
Is there a reason you don't just replace the bearing?
Old Oct 16, 2014 | 04:22 PM
skaternak's Avatar
i replaced it already, but while i was driving, the circlip came off. (dont know how it did, but it did). i just dont wanna go buy another one unless i know for sure this one has went bad. it has only been on for about 3 days.
Old Oct 16, 2014 | 04:24 PM
You or a professional clearly needs to replace the wheel bearing, so I'm not sure what answer you are looking for here.
Old Oct 16, 2014 | 04:28 PM
skaternak's Avatar
ok i'll try to explain it again. I've just replaced my front wheel bearings. The passenger side circlip that holds the wheel bearing into the hub fell off. Now one of my wheels has freeplay. And I am not sure if it is suppose to have free play or not without the circlip (snap ring). I am not sure if the circlip keeps the wheel from having free play.
Old Oct 16, 2014 | 04:38 PM
Sorry, but the answer seems so obvious. A part, the circlip, that helps to hold the bearing in place has fallen out and the bearing is now making noise.
The bearing install job was botched, so it needs to be redone. Am I missing something?
Old Oct 16, 2014 | 04:40 PM
skaternak's Avatar
It doesnt make noise when i spin it by hand. Does that matter?
Old Oct 16, 2014 | 04:42 PM
The service manual tells you the freeplay tolerance. Is the freeplay out of spec?
No matter how you look at it, the hub must come back off because at the very least the circlip must be installed.
Old Oct 16, 2014 | 04:45 PM
skaternak's Avatar
I cant really check it because there is no circlip on it. What I was asking before was "is there suppose to be some freeplay if the circlip is not on there"
Old Oct 16, 2014 | 04:46 PM
Old Oct 16, 2014 | 05:05 PM
skaternak's Avatar
it is off but i cant put in the new circlip yet because i need to find circlip pliers cause no place over here as them.
skaternak's Avatar
i will get back to you when i get them on. the only way to find out if theres free play is when i put the clip back on. thanks for your help ron
Old Oct 16, 2014 | 05:06 PM
When you reinstall the circlip, recheck the freeplay.
Old Oct 16, 2014 | 05:11 PM
skaternak's Avatar
that was exactly what i was going to do. thanks
Old Oct 16, 2014 | 05:23 PM
NotARaCist's Avatar
I never narc'd on nobody!
You don't have Sears or KMart in California? You can't order a pair from Sears.com? Basic tools that everyone should have. Circlip pliers are cheap, and extremely useful for a LOT of things on a car. They rank pretty high on that list.
EyePhoto
11
Sep 19, 2013 02:21 PM
EJ8mike
Mar 13, 2013 06:28 PM
Shooktd
11
Dec 3, 2011 09:16 AM
Blamm!!
Oct 8, 2008 06:51 PM
bgslash98
Apr 22, 2008 07:21 AM
