92 d16z6 Startup issues
Old Oct 14, 2014 | 09:53 PM
Swerve_EG's Avatar
Default 92 d16z6 Startup issues
I have an eg dx with a D16Z6 swap, currently I'm having progressingly worse startup issues, currently it will start and go to 1k rps then immediately drop to 200-300, throw a cel, then pop back up to normal, all in 3 seconds tops, does it when hot or cold. The reason I'm worried is its progressively gotten to this point.
I recently changed iacv and cleaned the fitv (to fix bouncing Idle on warm up) possibly creating this problem?
Old Oct 15, 2014 | 05:56 AM
Former User's Avatar
Default Re: 92 d16z6 Startup issues
Is there a good reason that you didn't post the CEL code?
Old Oct 15, 2014 | 10:04 AM
Swerve_EG's Avatar
Yea the cel is only there for a second, like when you stall a car, it literally just flashes when the car is at 200-300 rpms
Old Oct 15, 2014 | 10:07 AM
When CEL turns on, leave engine running while you jump the service connector.
Old Oct 15, 2014 | 10:28 AM
Swerve_EG's Avatar
So even if the light doesn't show anymore I can still pull the code?
Edit: Just checked for vacuum leaks on iacv and fitv, gunna put some coolant in, also I have another fitv, but I'm really feeling like this is a fuel sending issue
Old Oct 15, 2014 | 10:59 AM
That's what I'm saying, as long as you don't turn the engine off.
Old Oct 15, 2014 | 01:00 PM
Swerve_EG's Avatar
I'll do that when I'm off work and get back to yall, also, idling is a little funky now
Old Oct 16, 2014 | 12:00 AM
Swerve_EG's Avatar
Not having the cel flash anymore, but things are getting progressively worse. Starter sometimes has to turn for a little longer than normal, also if not given gas engine will stall out completely immediately. My list of things to change/test/replace
Spark Plugs
Fuel Pump
Iacv
Fitv
Ground valve cover better (was loose)
Main relay
choppyEG
Oct 13, 2013 12:37 PM
wazman
May 6, 2009 10:13 AM
brownsEF
Apr 10, 2009 04:16 PM
Gant
Sep 15, 2004 10:13 PM
