alternator dies, battery dies, burnt electrical smell in underhood fuse box
Old Oct 14, 2014 | 06:14 PM
patino209's Avatar
Default alternator dies, battery dies, burnt electrical smell in underhood fuse box
Ok so this is the second time this happened in about 4 months and the first time I had to replace the alternator and battery. Im driving in my 95 civic and my stereo starts cutting out, speedometer and tach go out, soon my headlights go out and im screwed. I pop the hood and check my wires and they all look good but i pop open the underhood fuse box and I smell burnt electrical. I checked all the fuses and they all look good. Checked voltage at my battery and it is not receiving a charge. What could be the problem? Maybe a short somewhere?
Old Oct 14, 2014 | 06:31 PM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: alternator dies, battery dies, burnt electrical smell in underhood fuse box
sounds like the electrical load detector built into the fuse box, something is causing it to short out
Old Oct 16, 2014 | 08:07 AM
patino209's Avatar
Yea its not the alternator. I just got it tested and it passed. How can I test or check the load detector?
Old Oct 16, 2014 | 02:49 PM
patino209's Avatar
Should I just replace the whole fuse box? I took out the fuse box and unplugged the connectors and they were all packed with white lithium grease.. is that ok?
Old Oct 16, 2014 | 06:50 PM
holmesnmanny's Avatar
Yes thats normal. Its dielectric grease. Pull another fuse box from the junk yard. The eld is built in.
Old Oct 17, 2014 | 02:28 PM
patino209's Avatar
Ok thanks. I will go get a new fuse box and try it out. Also I checked the connections on the ecu and I see some wires connected to another wire and to another wire. Dont know if someone did that or if its supposed to be that way, but it doesn't look right.
hondaEg_808
26
Jan 19, 2015 03:27 PM
aymen_a22
Dec 24, 2013 09:07 PM
alperx
Nov 27, 2012 05:47 AM
