2000 civic ex starting problem
Old Oct 14, 2014 | 05:53 PM
Heydarrylhey's Avatar
Default 2000 civic ex starting problem
Hey guys, I'm new here and I was wondering if I can get some help. So for the last few months my car has been having this weird starting problem where it would start up perfectly fine in the morning but after I stop the car after driving for a while, it doesn't wanna start. I'd have to wait about 30 min until it would start up again. I replaced my starter with a brand new one but I'm still having the same problem. The fuel pump primes, cel goes off, battery was replaced earlier this year, and all of my electronics work fine. All I hear is a click coming from the starter. I'm kinda stuck on what could be the problem. Any thoughts?
Old Oct 14, 2014 | 06:19 PM
Former User's Avatar
Default Re: 2000 civic ex starting problem
With transmission in neutral, run two wires directly from the battery + post to the starter solenoid and motor connections. Does it crank every time now?
Old Oct 14, 2014 | 06:50 PM
I'll give it a try tomorrow morning since it's dark out where I am. I'll post an update by then. Does it matter what wire I use?
Old Oct 14, 2014 | 08:00 PM
Use a jumper cable for the starter motor. A small wire should be fine for the solenoid.
Old Oct 15, 2014 | 10:51 AM
So I connected the wires but It still clicks. Any thing else I should try?
Old Oct 15, 2014 | 11:00 AM
Do you have a multimeter?
Old Oct 15, 2014 | 11:25 AM
I don't but I'm pretty sure I can get my hands on one. What should I be poking at?
Old Oct 15, 2014 | 05:14 PM
Measure resistance (Ohms) between the top of the transmission and the (-) battery post.
Old Oct 16, 2014 | 08:56 PM
I haven't gotten a hold of a multimeter yet cuz my friend is letting one of his other homies use it. But after being stuck at my local vape shop for about 20 min trying to start my car, I got a CEL once it did start. Would this be a clue to my starting issue or do I have another problem rising? I'll be checking the CEL tomorrow at work but I was just wondering if there would be a possible connection
Old Oct 17, 2014 | 06:48 AM
Just an update on the CEL. It's P1359 and it said something about TDC and the crankshaft position. I searched it up and it was talking about a sensor near the timing belt (from what I understand) or check my distributor. Any thoughts?
Old Oct 17, 2014 | 07:21 AM
You found the problem. The code is for sensors inside the distributor. Do the circuit troubleshooting in the service manual.
Old Oct 17, 2014 | 08:13 AM
Fasho. Thanks for the help and the fast replies. By any chance do you know anywhere online I can find the service manual? My car didn't come with it when I got it last year.
Old Oct 17, 2014 | 10:27 AM
Google is a gold mine.
Old Oct 17, 2014 | 12:02 PM
joey1320's Avatar
I don't think any car, in the history of the automobile, has ever come with an actual shop manual. If you are referring to an owners' manual, then yes those do come with the car, but that won't have the info you need.
https://docs.google.com/file/d/0B_Oq...rive_web&pli=1
Old Oct 18, 2014 | 08:05 PM
I took a look at the distributor today and all the wires/plugs looked fine. I noticed some wear on the rotor and the cap (perhaps I should replace this). I sprayed the connections with alcohol and made sure that they were on pretty good as well. It started okay for a while but later on in the day, I heard the clicking again. This time I was with a friend so we pop started it. Am I looking in the right place? Do I have to look deeper into the distributor? I also reset the CEL and it hadn't come back on
Old Oct 19, 2014 | 01:39 AM
Miguel h's Avatar
Old Oct 19, 2014 | 01:41 AM
Miguel h's Avatar
You my wana check the voltage coming out of your ignation switch.
Old Oct 19, 2014 | 01:56 AM
You have electrical problems. Just buy a multimeter.
Old Oct 19, 2014 | 05:44 PM
Alright I bought myself a multimeter. Now where do I start?
Old Oct 20, 2014 | 05:23 PM
Do I check for voltage on the wires outside and inside the distributor? What kind a readings should I be getting exactly?
BistaYang
Jan 28, 2013 07:35 AM
civicboy420
Aug 8, 2011 07:30 AM
kyleviney91da
Nov 22, 2007 02:56 PM
whatcivic
Dec 6, 2005 05:20 PM
brinks
Sep 19, 2002 02:39 AM
