EG getting no electricity
Old Oct 13, 2014 | 08:30 PM
EGhachiback's Avatar
Default EG getting no electricity
Hello, I have a stock d15b7 in my 1992 Eg civic hatch, and I am geting no electricity. Ok so heres the deal, I was parked at a gas station and then my car wouldnt turn over, all I got was the electricity, and I could hear my fuel pump prime, I even tried getting a jump but nothing still. After about 20 times of trying it finally turned over and I drove it straight home and then it never came back on after that. So then I let it sit for awhile, then my battery died, and my friend hooked up the actuators with the locks or something so I can only access my car through my remote. I can access my hood from outside so I charged it, put it in, (I have done this a few times before), and then now I am not getting any electricity anymore. Before this happened I tried to fix it, and get it running. I got a new starter, good battery, good alternator w/new belt, good spark plugs, new negative battery cable, new battery terminals, new dizzy cables, and dizzy cap+rotor+icm. Still nothing happened. Another honda-tech member said I should change my main fuse (50am ign.) which I did, and then nothing still. My light fuse (40amp) , and heater motor fuse (30amp) are a little corroded, but I don't think it would stop me from getting any electricity. I only know where 2 grounds are which are the one from the battery, and the one that is connected to the head, those are good. I bought a continuity checker, and everything seems to check out from what I know. I also bought a main relay but I cannot get in my car. Please help me Honda-tech, I'm honestly stumped... Thank you
Old Oct 14, 2014 | 05:20 AM
EGeezy's Avatar
10 Year Member
Default Re: EG getting no electricity
Have you looked at the ecu?
Old Oct 14, 2014 | 05:32 AM
instrument's Avatar
by no power you mesn when you turn your key nothing lights up?
if so could be your ignition switch, but then normally the car would still turn over.
could be your thermostat ground.
also what happens if you wire your starter directly to your battery?
Old Oct 14, 2014 | 06:03 AM
sowellman88011's Avatar
Sounds like something went out and is grounding out tho it could still be the ignition switch being completely out but you cant get in to try it. What about the hatch did your friend disconnect that 1 too?
Old Oct 14, 2014 | 06:16 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
this is the same thread that was locked yesterday
Old Oct 14, 2014 | 06:17 AM
https://honda-tech.com/honda-civic-d...icity-3225542/
Old Oct 14, 2014 | 04:59 PM
Former User's Avatar
Correct.^
OP - You failed to read suggestions in your original thread and take action. Warning - Don't create another thread until you have tried everything suggested in your original thread. Don't waste member's time.
carlosd68
26
Sep 18, 2012 06:00 PM
Blacknight117
May 11, 2011 01:49 PM
jwizzie2001
10
Oct 13, 2008 11:39 AM
Diet coke boii
Sep 30, 2007 09:15 PM
LSEGHATCH
Dec 5, 2005 07:10 PM
