Water Injection on NA
Old Oct 12, 2014 | 07:08 AM
DylanGSR_eh9's Avatar
Default Water Injection on NA
I can find a lot of info on water/meth kits for turbo cars, and I want to do it to my NA Gsr, has anyone done it with no turbo/supercharger? Any pros and con's with this setup? Any info is constructive, thanks HT!
Old Oct 12, 2014 | 09:24 AM
Tyler Dirden's Avatar
I am Jack's...
Default Re: Water Injection on NA
Water injection is a useful system for N/A but for lesser reasons. The system will allow you to control detonation on high compression engines or motors consuming less than correct fuel octain. It is especially helpfull in the sumertime with high heat and an edgy tune that will rapidly produce detonation spikes when under full loads. These systems do work and well. There must be some kind of intelligent controller with failsafe options to make it FULLY reliable and these run the system cost way up.
It can also be implemented manually while driving to actually steam clean your combustion chambers and keep carbon deposits from accumulating.
A good system like the AEM set up will cost as much as a nitrous system with no power increase to your combination. It is the user controls on these systems that make them versitile. A cheap system is a sure waste of money as the pumps are allways failing.
Old Oct 12, 2014 | 10:25 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
devils own has a much more versatile system then snow, they have many more options, and flexibility, I have a high compression carburated motor, and I'm interested in a system to prevent detonation at higher RPM, you shouldn't spray below about 4000 rpms anyway as it will tend to quench the flame front
Old Oct 12, 2014 | 05:48 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Nobody cares to know WHY the OP wants water injection in his NA car? Its helpful depending on what is done to the car.
Old Jan 28, 2015 | 10:23 PM
Sorry for the late reply, but my dad and I are wanting to fully build 350 for his T-bucket and I was researching Water injection but I could come up with only boost related results.
Thanks for the info though guys!
Old Jan 29, 2015 | 01:19 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
I'm glad you were able to get the information that helps you.
This inquiry doesn't appear to be for a Honda per say and is pretty universal information.
I believe the information is helpful as it stands now so should be available for others to find looking for some general information.
Thread is closed before it deviates from being useful and also being it's not specific to a 92-00 Civic/Del Sol.
This kind of Topic might be better suited in the NA section if not the Misc/Tech section.
cvelazquez
Apr 26, 2012 04:28 PM
jt-sport
Nov 1, 2008 10:40 AM
denraweb
Oct 10, 2008 03:38 PM
