F20b into Prelude swap(ECU confusions)
Old Oct 8, 2014 | 04:38 PM
ThePrelude's Avatar
Icon6 F20b into Prelude swap(ECU confusions)
Ok, Im not good with ECUs and Tuning buh ive searched alot and I am still confused. Im swapping a F20b into my 1997 stock prelude. I am going to be using the original prelude tranny. Can I use the h22a4 ECU or do I have to use the F20b ECU? and does transmission affect ecu?
Old Oct 15, 2014 | 11:25 AM
94dxcoupe's Avatar
Default Re: F20b into Prelude swap(ECU confusions)
The ECU will need to be setup for the same transmission [ie: if you are using an auto transmission, then your need an auto trans ECU]. The stock H22 ECU will be dumping to much fuel for a 2.0 engine. I'd recommend converting to OBD1 (using an OBD2A to OBD1 jumper harness) and using a tunable OBD1 ECU setup (P28 with Hondata S300 or P28 with Neptune/Demon). Check out xenocron.com , www.hamotorsports.com , etc.
MyHotsh
Oct 10, 2025 05:58 AM
Phet7
Oct 5, 2011 09:29 PM
2000siturboR
May 20, 2008 11:13 AM
MrJasey
Mid-Atlantic (Sales)
Mar 13, 2008 06:07 PM
preludesi2188
Nov 22, 2005 10:24 AM
