B18 stroker kit
I personally have not. But here's a link to search on here with tons of results. Should be able to get what you are looking for from them.
https://honda-tech.com/search.php?query=crower+stroker&do=mobileSearch
If you're looking for HP gains from a stroker kit, you have already started with the wrong mindset.
Stroker kits should be used in the mindset to increase DISPLACEMENT, the root of where power starts. Read up.
cylinder head is where its at. Good port/bowl work, cams, intake manifold and header and then of course the tune. I on a stock Ls stroke, might be high compression, but all my power is coming from the head/IM/header
