H22 turbo civic hatch -$6250
For sale is a 1992 Civic hatch with rear 3rd door. Only selling in order to start my prelude project. This car has been meticulously maintained and although the cosmetically not perfect, it is perfect under function. I bought the car not running as NA and very deprived. I replaced all suspension bushings (other than compliance which were on back order from hard race), suspension, rear brake conversion, engine mounts (had ebay junk). My biggest concern with this car was making it not drive like a 22 year old car and I believe I have done that well because it drives great. No suspension noises that you typically hear and drives SMOOTH!
This is the perfect project car for someone looking for a car that has the right components but wants something that has the looks as well. Ive done a majority of the work so far but i only cared that it was fast for the most part. And fast it is.
With that said, here is a mod list that i will attempt to make fully complete:
H22a stock bottom
EuroR head (ported, unknown work)
Crower valvesprings and retainers
ARP head studs
Custom manifold by me, heat wrapped
Turbonetics billet 5454
Tial MVS 38mm
Tial Q 50mm bov
go-autoworks charge piping and intercooler
2-5-3" up pipe
Turbowerx turbo drain pump
-6AN aeroquip socketless hosing for drain system
Rosko Racing Euro R intake
Rosko Racing Fuel rail
BDL 68mm throttle
Fuel Injector Development 1000cc
Aermotive FPR
FuelLab fuel filter
-6AN feed and return lines (Aeroquip socketless hosing)
Custom valve cover
-10AN aeroquip socketless hosing for crankcase ventilation
KStuned crankcase tank
TJtuck harness
Hasport 70A mounts
DSS swap axles
Koyo Radiator
parts store slim fan
VIS CF hood
Carbon fiber duck bill
Tanabe sustec coilover system
Skunk2 Pro upper control arms
Hardrace bushings all the way around
-- except compliance
Skunk2 rear camber kit
Skunk2 rear LCA
Goodridge stainless brake lines (rear)
XXR 531 flat black. 16x8 +20
225/45r16 BFG KDW2 (lots of tread left)
MOOG front lower ball joints
Hardrace tie rods (not installed)
Rear disk, parking brake conversion
NRG race bucket seat
Simpson Harness
custom harness bar
Personal Steering wheel
NRG quick release
NGK AFX wideband
P28 tuned with Neptune (boost by gear)
382whp at 15psi pump gas
450whp at 15psi rocket brand e85
$6250. Located in NorthWest Florida
H22a stock bottom
ARP head studs
Tial MVS 38mm
Tial Q 50mm bov
2-5-3" up pipe
BDL 68mm throttle
Aermotive FPR
FuelLab fuel filter
Custom valve cover
TJtuck harness
Hasport 70A mounts
DSS swap axles
Koyo Radiator
VIS CF hood
Skunk2 rear LCA
Simpson Harness
custom harness bar
NRG quick release
NGK AFX wideband
jared50438
May 19, 2011 10:23 PM
