need help installing electric oil pressure sender
Old Oct 6, 2014 | 07:01 PM
No_jdm_fanboys's Avatar
Default need help installing electric oil pressure sender
Hey all need some help running into clearance issues trying to install a sender for my gauge
Engine:b18a1 bottom b1 head
Car: 95 integra
5sp
Oil sender for my sunpro gauge doesn't clear the oil filter sandwich plate has been tried but gaskets are no good would prefer a direct to block type set up willing to get a hose made to replace dummy light any suggestions ?
Old Oct 6, 2014 | 09:12 PM
m4xwellmurd3r's Avatar
Get an adaptor to turn tge stock pressure sender port to a 1/2npt thread. Use a hose to go from there to a T fitting. Get an adaptor to go from 1/2npt back to honda threads for the stock pressure switch, and screw the pressure sender for the gauge on the end of the T.
Other option is use the hose and stuff, but ditch the stock dummy light sensor and T fitting and use the hose to relocate the oil pressure sender.
Old Oct 8, 2014 | 08:49 AM
Totally thanks man knew I could use a hose was acratching my head on thread sizes good to know I can do it though I deff don't need a dummy light as once this comes on major damage is already taking place
Old Oct 8, 2014 | 08:51 AM
I like the hose relocation idea don't really trust t fittings my car is lowered (which I hate) so that t fitting would be put under a lot of stress
Old Oct 8, 2014 | 06:47 PM
4drboostking's Avatar
Default Re: need help installing electric oil pressure sender
You dont need the dummy light even hooked up. Its worthless once you have a real pressure gauge. Just leave the connector unconnected and the light will never light up again.
Old Oct 16, 2014 | 08:34 AM
Thanks everyone for the advice sender is bad so I gotta order a replacement
Kuhniee
Mar 31, 2011 07:45 AM
ufakeit
18
Sep 11, 2009 12:44 PM
afplayboy17
Oct 6, 2007 10:39 AM
Evolsport
Dec 28, 2002 08:54 AM
blackteg
Jun 19, 2002 09:10 AM
