corner light has no power
Old Oct 5, 2014 | 04:11 PM
johnp88gt's Avatar
Default corner light has no power
i just bought a del sol. it had a headlight socket spliced onto the corner light. i took it apart to put the right socket on and i tried to test for power. the power was there. i accidently let the wires touch together and lost all power. all lights on the car work. the corner light does not work for running lights, turning signal or hazards. only the one light. its the driver side front corner. i tested for power using the negative battery terminal. any info will be helpful. thanks in advance
Old Oct 5, 2014 | 05:22 PM
A1_Wanderer's Avatar
Default Re: corner light has no power
Maybe it's the bulb that burned out, if all else is working except that light.
Old Oct 6, 2014 | 04:35 AM
johnp88gt's Avatar
There is no power for the bulb to work.
Old Oct 6, 2014 | 12:06 PM
johnp88gt's Avatar
Does anyone know where the power wires runs to coming from driver side corner light
Old Oct 6, 2014 | 07:02 PM
Jaxis's Avatar
Checked fuse?
Old Oct 7, 2014 | 12:04 PM
Can't be a fuse since other lights work, it's going to be that wire .
Old Oct 7, 2014 | 08:33 PM
Former User's Avatar
Post pictures of the bulb socket and the wires coming from the rear side of the socket.
DA_Boy_626
Feb 22, 2012 10:37 AM
OneFire
Jun 2, 2011 09:07 PM
averyvm
May 22, 2008 04:40 PM
TekBuDDy
Feb 14, 2007 10:41 AM
amb4081
Dec 14, 2004 10:53 AM
