Honda CR-V & Element 2WD & 4WD Element & CR-V
2008 CR-V A/C Return air filter
Old Oct 5, 2014 | 12:40 PM
conejo77's Avatar
Default 2008 CR-V A/C Return air filter
Unable to locate the a/c evaporator filter online. I am not referring to the cabin air filter, this one goes on the outside of the unit under the glove box.
It is a white fiber material 16" long and 6" wide at the widest part. Does any one happen to know a part number please or location where I may find one.
Thank you
Old Oct 5, 2014 | 01:09 PM
UK-Kev's Avatar
Default Re: 2008 CR-V A/C Return air filter
Hello,
You need to drop the glove box completely down – If you look at the glove box door torsion rod, you will see it clips off and the others side of the door can be spurge off with the aid of a screwdriver. Then it’s just a simple case of clipping out the cabin filter.
See the utube link below.
Happy CR-Ving
Kev
Old Oct 12, 2014 | 07:55 AM
conejo77's Avatar
UK-Kev
I appreciate the reply but you need to read my original posting. As I stated, I am not referring to the CABIN AIR FILTER, which is located behind the glove box. The filter I am looking for is below the glove box, on the outside of the A.C. unit. I presume it to be a return air filter for the blower, judging from how dirty it is. I can not locate a part number of this filter much less find it on any website.
Old Oct 12, 2014 | 12:28 PM
UK-Kev's Avatar
Originally Posted by conejo77
UK-Kev
Re above apologies I should have taken more notice of your original message – Getting back to your question” filter on the outside of the AC unit” The reason why you can’t find any information is because I don’t think Honda fit them!!! Suggest you check with your local dealer to clarify.
Happy CR-Ving
Kev
Boopaa
May 18, 2018 04:57 AM
dpine
Sep 9, 2008 08:29 AM
odiumred
Jun 22, 2007 11:27 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
rev limiter
13
May 1, 2005 11:53 PM
