GSR eg6 rough idle after dyno tune
Old Oct 4, 2014 | 12:00 PM
sinisterEG6's Avatar
Default GSR eg6 rough idle after dyno tune
Okay so I have a 99gsr swap in my eg, I have owned the car for a number of months and had zero issues with it other than it running rich due the 450cc injectors without a tune. A few days ago I went to one of the local tuning garages and it tuned. It did great on the dyno and ran amazing on the way home (about an hour drive). When I started it the next morning the idle was very rough and bounced from around 1500 to 300 once it warms up it's fine. I've searched around but don't know where to start or if this could be a problem with the tune. I just don't see how it would be a tuning issue when it started and ran fine on the way home. Thanks
Old Oct 5, 2014 | 06:00 AM
boosted k20's Avatar
Default Re: GSR eg6 rough idle after dyno tune
Do u have a wideband in the car. What is the af when it idles rough. you may have to adjust the cold idle/startup
Old Oct 5, 2014 | 12:38 PM
I don't have a wide band or a af ratio gauge. I was just told by someone that it could be my cams making it idle like that on a cold start.
Old Oct 5, 2014 | 06:52 PM
mtber's Avatar
My guess without seeing the vehicle:
The issue is likely with the engine coolant & intake air temperature compensation tables not being tuned at cold start & warm up conditions.
Call the tuner, take it to them & let the car fully cool down & have them tune the coolant temperature compensation tables etc.
Old Oct 15, 2014 | 11:34 AM
94dxcoupe's Avatar
^^ what he said. Your tuner didn't finish tuning the idle, warm up, etc tables. Most people don't want to pay for the additional tuning time to do this so it gets left as-is :/
sinisterEG6
Oct 4, 2014 07:15 PM
TinoNT
Apr 14, 2013 06:11 PM
ncsi
Dec 19, 2012 08:56 AM
BoneStockDX
Mar 13, 2007 06:08 PM
1.9crxNA
Sep 19, 2006 08:13 PM
