Best way to tune an ITR in CA and still smog?
Old Oct 3, 2014 | 10:01 PM
PredatorGSR's Avatar
Default Best way to tune an ITR in CA and still smog?
I have an ITR that has an icebox and full hytech exhaust system, otherwise stock. I have the ability to swap out the exhaust system every 2 years in order to be able to smog in CA.
What is the best solution to be able to have my car tuned by a good tuner, but still be able to revert things back to stock every 2 years for smog?
Thanks in advance.
Old Oct 4, 2014 | 07:28 AM
mattyfo0z's Avatar
Default Re: Best way to tune an ITR in CA and still smog?
pick up another untuned ECU to run when you put the car back to stock?
Old Oct 5, 2014 | 01:49 PM
underrated99si's Avatar
Get a P28 ECU install hondata S100-S300 and a OBD2 to OBD1 jumper harness have it tuned. On smog day take off header and swap in factory ECU.
Old Oct 8, 2014 | 07:40 AM
Dark_Teg's Avatar
Your bang for the buck will be horrible with the minimal mods you have.
Old Oct 9, 2014 | 12:10 AM
Outrun's Avatar
Just curious why an exhaust would matter for smog? I'm not familiar with Hytech but does it not use the cat?
Old Oct 9, 2014 | 09:22 PM
drmix's Avatar
Like most aftermarket parts its more than likely not CARB approved. Once they see the header youll fail.
Cali + aftermarket parts =
Old Oct 9, 2014 | 09:28 PM
Outrun's Avatar
Ok, I thought by full exhaust he meant a cat-back exhaust.
Old Oct 16, 2014 | 03:49 PM
wunfstgsr's Avatar
Loved
Community Favorite
Just pay to get the car passed pm me if you need this hook up. Or like they said have it tuned and when its time to smog use the stock edu and put back anything you modified thats not carb approved.
Old Oct 19, 2014 | 10:45 AM
tmkpres's Avatar
California smog is STRICT, I almost failed visual with the JDM OEM header. Ended up failing anyways. DAMN IT !!
Old Oct 27, 2014 | 11:55 AM
A1_Wanderer's Avatar
You guys gotta keep all the stock parts to do smog, as for headers I would keep the heat shield to make it look for normal. I'm in the process of legalizing my Ek with jdm itr swap and it's just a pain.
Old Oct 27, 2014 | 08:20 PM
Ender Ho's Avatar
it'll depend on the place too.
some places will turn a blind eye to the visual (go to a smaller shop), but most can't/won't help you if the ECU is triggering the CEL.
ask your local buddies if they have a smog guy...
Old Nov 3, 2014 | 06:21 PM
Rhetoric's Avatar
I have similar mods as you, just running a Jdm 4-1 with 2.5" exhaust. I am planning to go with a Hondata s100, the only additional modification for me would be a mild cam.
Being in CA, I keep my stock ecu, cat and header in storage.
Old Nov 6, 2014 | 06:14 PM
Mccormick009's Avatar
I hate to be a harbinger of bad news but just don't mess with it. I am pulling my hair out in the integra forum trying to fix someone else's project. I am trying to restore to CARB legal a modded car and the purge valve solenoid is driving me bat **** with check engine lights.
Old Nov 6, 2014 | 10:32 PM
redGSRguy's Avatar
Are you in the San Jose area? Get Hondata come to Synergy and get tuned. Swap stock ECU back in to smog.
jdmspoonitr
Apr 20, 2010 09:58 PM
gurlugotmilk
Feb 6, 2009 06:29 PM
deeksmooth
12
Jan 2, 2004 09:28 AM
Comma -1
Aug 15, 2003 04:25 AM
