270K Miles - What maintenence should be done?
Hello, I have a 1993 Honda Accord LX (5-speed) and today I hit 270,000+ miles.
My question is what maintenance should I be doing to prolong the life of my engine, tranny etc?
As always, thank you for your time!
Change fluids as need be, make sure you are up to date/mileage with valve adjustment, timing/balance belt replacement. Verify there are no leaks, no swollen or soft hoses. Look at bushings for tears, cracks, wear. A general look at everything on the car, pay attention to any new noises/sounds/feeling in the way the car drives.
Go over the whole car and if you see something questionable, describe it, or post a picture of your concern.
Thank you for helping,
Should I go ahead and change the timing belt, water pump and serpentine belt, spark plugs and boots?
- Timing Belt, Balancer Belt, Water Pump, Thermostat, (Timing Pulley + spring, Balancer Pulley + spring), (cam, crank & balancer seal), (power steering, A/C belt)
- Valve cover gasket + spark plug seals
- Spark plugs
- Coolant change
- Oil pump gasket
- Brake fluid bleed
- Check air filter
- Check PCV valve
- Clearn EGR & IAC & Throttle body
- Fuel Filter
flexylexy
Dec 19, 2020 02:21 AM
market525
Jan 13, 2011 06:50 PM
david118383
Sep 18, 2009 11:34 AM
