DevSport Inline Fuel Filter
I have a 1993 Del Sol Si that will soon have a B20b in it. I was wondering if anyone on here has any experience with these?
Are they good quality?
The product was made for B series and D Series Del Sol but being as the del sol only came with a stock B16 and a D16z6/y8, will it fit my stock B20?
Any information will be of the greatest help!
Link to product:
http://www.devsportusa.com/DevSport-...Sol_p_731.html
Link to product:
Never heard of it.. why not post a link or some info of the product your trying to get an opinion on..
IDK why people try these no name parts and ask about them when Russell and others have been used for decades and are trusted.
The filter they use is Russell. I will post the link now.
I just want to clean my engine bay up.
I just slapped a fresh coat of paint on the engine bay, tucked my brake lines, preparing for a wire tuck soon and I want to get that ugly fuel pump and return line out of the bay. This one seemed convenient because I know russell is a good brand and everything is black which kinda goes with the theme of my engine bay. Thats why I was wondering if anyone had any experiences with it.
Well im using a russell filter with -10AN fittings. I made my own as some of these are longer then you want.
Hope it has the proper fitting for the hardline.
It needs to be almost an exact fit or you will get fuel leaks.
If you don't want to justify your reason to purchasing this that is all on you. I still wouldn't pay that much for it. Rather build my own.
I said, up there^, I wanted to get it to take out the ugly stock fuel pump and clean up the bay. How would I find out if it will fit? I googled what size the stock fuel lines are and didnt find anything? Is there anything that I can do if I get it and it doesnt fit?
You can make a coupler out of fittings and **** but that wont look pretty so it isn't good enough for you OP.. Make sure you DONT coil the brake lines next to the master cylinder. And totally make sure its just floating around behind the block, not mounted to the fire wall or anything.
you know what OP, that booster and master cylinder looks ugly in your bay. You should get rid of that stuff too
Then he wouldnt have a fuel rail and injectors.
This is thread you need. Since im in a good mood here ya go
https://honda-tech.com/tech-misc-15/...tings-1452210/
