Engine Harness Help on 1993 Del Sol Si B20 Swap
I am currently in the process if doing a b20 swap into my 1993 Del Sol Si. I am running a chipped p28. I need to know what engine harness I need. I have searched the internet for this information and I have found nothing solid. What engine harness will do the job?
Any information to point me in the right direction is greatly appreciated.
If you've swapped over the OBD1 counterparts for the alternator, injectors and distributor it should be plug and play with your stock harness.
It is possible as I just remember my cousin having an obd1 del sol with an obd2 engine harness. I suggest sticking with an obd2a integra harness. Please note that I said "OBD2A" and not just "OBD2".
How unreal, I am also doing a B20 swap into my 93 del sol and also had a question about which harness to use. The only difference is mine is a B20vtec, I am using a B16a2 head. I do not have a Dizzy, ECU, Injectors or Alternator yet. Can you guys please inform me the best route to go?
Which ecu? If you're using a P28 then you could just use a 96-97 Del Sol Si or 96-01 Integra GSR, or just use your harness with either adapters or OBD2 alternator and distributor for a Bseries VTEC.
obd2 LS into 92 cx
should be similar to your setup
https://honda-tech.com/honda-civic-d...te-up-2239971/
I have an S that has been completely converted to an Si. Si harnesses were used throughout, even in the cabin. The engine setup is a B20B bottom end with a B16a2 head, relatively built engine if that matters. What would be the best OBD/harness route to go for? Again, I do not have a Dizzy, ECU, Injectors or Alternator yet, so I believe I am at free will to go any route suggested.
Got it. We'll I am going to weigh my options. I will let everyone know what I get after the swap to ensure it works. Thank you, everyone!
Just wanted to add this for the OP
From what I have read is that all 92-95 civics, all del sols and intergra have have essentially the same set of plugs from the shock tower to the ecu, you may not have all the wires though vtec etc ..., all 94-01 teg harness are the same at the shock tower end, whatis different is the actual plugs that are on the engine side for the sensors, fuel injectors alt etc, so you will want an obd 2 harness from a teg that has the engine side plugs match up to the engine, so if the sensors etc are obd2a or obd2b whatever that the kin of harness you want as they will all plug in at the shock towers
hope this helps
hope this helps
hope this helps
hope this helps
Eg5ir1
Jul 20, 2013 06:58 PM
stiffinEK
Nov 22, 2009 04:49 AM
brizjuan
May 1, 2004 09:23 PM
