Re: Cars For Sale: Integra TYPE-R's - Oct/Nov 2014
Parting out my 98 ITR
Clean title (in hand)
107k miles
Seattle WA
206-380-1592
I was in the process of prepping the car to be painted inside and out so I removed EVERYTHING from the car, windows, interior, wiring, you name it. The suspension and hard-lines in the engine bay are still all intact, though everything else has been removed and in boxes.
I would like to part it out as I am busy with life and do not have time to finish the car for what looks to be a long time at this point.
Engine (original to car, number matching)
-Complete swap, with EVERYTHING besides header and muffler. This means every single thing needed, including the OEM exhaust, radiator, throttle cable, etc.
Recently replaced the timing belt and cam seals.
Near brand new, flawless condition OEM ITR transmission with under 1000 miles, along with clutch and pressure plate.
$4850
Complete ITR suspension and five lug conversion (not just 5lug hubs and spindles, this is the full conversion, the only way to get the absolute true handling as on the ITR).
-This includes EVERYTHING, down to the front and rear control arms etc. All bars, you name it. CW OEM wheels with no curbs but do have rock chips and new tires with almost no wear.
$2000
Clean title Shell/ Rolling chassis on 4 lug suspension.
-All exterior panels (only parts number matching are hatch and rear bumper)
-All interior panels and gauge cluster
-Missing headlights, front seats, arm rest lid, climate control
$4500
Or $7,500 for it all.
Again, the suspension is still intact and on the car for the time being, don't know if someone may want the shell with it and due to the fact it only takes a short amount of time to remove, it will stay on the car until otherwise.
The parts are priced accordingly to the current market.
The transmission is almost brand new so that makes it more fair than others, as used engines with transmissions go for about the same numbers.
The suspension comes with struts/ springs/ all control arms/ front & rear sway bars/ trunk bar/ front strut bar/ rear under bar and new tires.
The clean title chassis is hard to put a number on, as many know these cars with clean titles are extremely rare and to come by a clean title shell is even more rare.
Absolutely no trades, I am not interested in anything other than to sell this car.
I appreciate your interest & time and wish you luck on you search.
Re: $2000 NBP USDM INTEGRA TYPE R #00-0187 CLEAN TX TITLE $10,500
For Sale is a USDM 2000 Integra Type R #00-0187 clean Texas title under my name, no wrecks with 134, xxx miles. $10,500
Need it gone ASAP or will unfortunately part out
INTERIOR: All original integra Type R interior, badged armrest, OEM ITR front seats, OEM ITR rear seats, OEM ITR floor mats, OEM ITR CLUSTER OEM ITR clock, sterring wheel, shift boot and all carbon fiber trim. No spare tire, no jack, No radio or rear speakers.
Autopower 4pt roll cage (really stiff and firm)
Shortshifter and innovative shift linkage has New brakes with steel braided brake lines on all fours, spherical rear trailing arm bushings fairly new
EXTERIOR: Stock ITR body no dents, cut rear bumper for track use (will get original rear bumper with purchase and front right turn signal air intake duct), rear wiper delete, shaved antenna, white jdm ITR 16 inch wheels wrapped with bridgestone b500 si 205-50-16 (80% tread left) paint 7/10 normal wear and chips
ENGINE: stock USDM ITR P73 ECU, sleeved GSR block, hi compression pistons, Eagle rods,
JDM ITR head with ferrea valves, keepers, retainers, dual valve springs, buddyclub spec 3 cams, AEM adjustable cam gears, AEM fuel rail, USDM ITR header, on September 5, 2014 I replaced distributor, axles, battery, ngk spark plug wires with new parts, fresh oil change with Lucas Oil stabilizer as I've been doing for years. Has no name ebay cat back exhaust with innovative test pipe (sounds real aggressive not rice). Has A/C and Power Steering.
***Due to not converting the vehicle to OBD1 like I normally do, it does have a CEL for high emissions because I am using a test pipe instead of a catalic converter and the 02 is not reading properly
*** another CEL for the IACV which I changed out but it still throws the code for some reason
easy fixes but I attend to my PYR because I am keeping that one and it became a money pit
NO TRADES!!!
CASH ONLY!!!
NO WINDOW SHOPPING!!!
SERIOUS BUYERS ONLY
DONT WASTE MY TIME please
$10,500 Need it gone ASAP or will unfortunately part out.
Located in El Paso, TX
PM me if interested and for more information
txt for more pictures
915-726-2060
2001 Type R 61,600 Miles #01-0101 CLEAN TITLE
$18,000
200 Miles GSR Block 81mm Arias Flat Piston
Eagle Rods
ACL Bearing
Block Guard Supertech
ARP Studs
Oil Catch Can
Head Stock Type R
Camshaft Type R
Retainer, Spring and Valve SuperTech
Manifold Type R Coating
Throttel 68mm
Injectors RC1000
Walbro Pump
GSR Transmission 4.40
NEW DP Scatter Shield
NEW Quaife LSD
NEW Tilton Cluch Twin Disc
NEW DSS Axle 5.9 for 5 Lugs
Custom Turbo Manifold Top Mount A/C Compatible
Presicion Turbo 6262
Blow Off Tial
WasteGate Turbonetics
Hondata S300 and Boost by Gear (Tuned by CMB)
VP C16 ONLY
Type R JDM Original Seats Red
Type R Wheels 15"
Front Tire BFG 225-50-15
NEW Rear Tire Falken
ARP Wheels Nuts all around
Brake ABS
NEW Roll Cage Certified for 10.0 1/4 Miles
NEW Seat Belt G-Force 3"
NEW NRG Traction Bar
NEW Suspension Full Coilover Drag Race
NEW Autometer PRO Shift Light Connect to Hondata S300
Low beam 3000k Yelow Light
High beam 8000k HID
MSD 6A
COLD A/C
NEW Race Wheels Weld 15x10 5x114.3
NEW Race Tire MT 22x8x15
107k miles
Seattle WA
206-380-1592
$4850
$2000
$4500
FS: 2000 Pheonix Yellow Itr Shell "Clean Title" 2 owner Located in Ny (Garage Kept) Originally from Georgia *Rust Free* milaged last clocked @ 127k ,yes its k ready but uncut! can also include original tranny side mount bracket incase you decide to go back to B series thats all that will be needed; The shell is pretty back to stock besides suspension Apex-i N1 dampers type V coilovers! , literally missing front seats and front bumper,will include rear bumper needs to be paint matched.. $5k firm priced to sell.... text 347-861-9269
Up for sale, trying to move out to the Pacific Northwest and will not be needing my R. Located in DFW, Texas. Car is Ebola free. 2000 Acura Integra Type R
Pm me more info. I'm in the market for a ITR preferably PY
WTB:
In the market for a 00-01 PY ITR
Clean title, all original, no swaps. Please comment or PM if you or you know someone who is selling, thanks. Email me @ oneyamahar6@gmail.com or pm me on my HT account. Thanks
For Sale – 1998 Integra Type R
Title – Florida Certificate of Destruction
Location – South Carolina
Price – $7000 obo
I’m selling my Integra track car. I purchased the car as a theft recovery shell in Orlando FL. The paint was faded with a few dings and dents in the body. The car has been painted in graffiti over the OEM paint, this is not a wrap. This car has performed flawlessly on track with the exception of the first time out with transmission issues. The transmission was replaced after this event with a new OEM transmission from Baranco Acura and currently has approximately 1500 miles on it. The engine is a healthy 100% stock B18C5. The engine was purchased as an OEM replacement longblock from Acura Carland and currently has approximately 22,000 miles.
Modifications
Injen CAI
JDM 4-1 copy header (Strup)
KTeller 2.5” mandrel bent exhaust (no cat)
JDM Circle 2.5” twin loop muffler
Fluidyne dual core aluminum radiator
Baffled oil pan
Omnipower Coilovers (12k front, 10k rear)
Fidanza 7lb flywheel
Exedy Stage 1 clutch
Hawk Blue front pads
Carobtech XR3 rear pads
New Autozone rotors
Kirk 6 point cage with door bars and padding
Wink 4 panel mirror
USRP aluminum seat
Fastline Performance shifter
Mugen shifter bushings
Autometer Oil Temp, Oil Pressure, Coolant Temp gauges
15x7 Rota Slipstream wheels
Toyo RA1 tires (plenty of meat left)
Spare set of RA1s (used) included
26’ Haulmark enclosed trailer with A/C also available.
WTB: I'm looking for a PY ITR 00-01. Has to be all original , CLEAN TITLE, OEM Interior, nothing over high 100s miles. Minor upgrades are ok , but nothing major. I'm located in San Antonio TX. So the closer the car the better offer I can give you. You can reach me via text to 626)991-2984 or pm me. Thanks..
I have an all original 1997 Japanese RHD Type R. It needs a paint job. Some scratches and minor dents from shipping. 85k KM ONLY. Runs amazing, just needs paint. Could use new weather stripping on front windshield and left side door/window seal (on the door under the window). Could also use new paint on the rims. Otherwise the car is clean.
I have 14K into the car, just had it shipped to me from Tokyo. Not really feelin the RHD. I thought id see what i could get for it. Pics to whoever is interested.
WTB -- I'm looking to buy an ITR preferably in Phoenix Yellow, White, or NIGHTHAWK Black Pearl. Would possibly consider a very clean FBP though. Needs to be all original or at least have original parts. Lower miles the better! Tasteful/minor mods would be fine. I'm located in Denver, CO but am willing to travel for the right car. Please send me a PM with basic info on here and we can go from there regarding texting/calling. Thanks!!
