Going GSR
Hello guys well I finally made the jump from my single jingle to the B-series.
I recently picked up a GSR block, crank, and rods and a Top proline head, I would like to build the motor for high compression 11:2-11:8 and stay with pump gas 93 octane. What advice would my fellow NA gurus suggest I go with??
currently these are the parts I have for the build are:
Head:
OBX 68mm TB (came off pervious build)
Blox IM
AEM Fuel Rail
RC Injectors 1000 (came off of pervious build)
Hondata 4bar map sensor (came off pervious build)
Block:
OEM HG
ARP head studs
GSR crank
GSR water pump
GSR Oil Pump
GSR rods.
Head:
Blox IM
AEM Fuel Rail
Block:
OEM HG
ARP head studs
GSR crank
GSR water pump
GSR Oil Pump
GSR rods.
I would look into a performer x intake over the blox. It will beat it all over. The fuel rail is not necessary along with a 4 bar map sensor.
If it were my build i'd sell the RC's and look into IDs/grams/RDXs for injectors, better spray patterns.
You're on track with everything else though.
I'd also use JDM R pistons.
just my .02
just my .02
Thx Sleeper
Only reason why I am going with the RC's and the 4 bar is cause it came off my last build figured I could save money. but I do still have my Omni 3bar I could use for the build.
I like ur sig.......
Check this out:
http://www.ipgparts.com/store/Acura-...Injectors.html
AnT PERFORMANCE
Aug 5, 2011 06:06 PM
slowsleeper
28
Oct 16, 2008 10:31 AM
b20.eg
Jan 27, 2007 05:58 PM
