check engine light came on..
the light came on last night while taking a high speed turn...
my question is, do i need to take it to the dealership i purchased the car from, or can i take it to any acura dealership?
you can take it to any dealer... you could see if it throws code
http://www.c-speedracing.com/faq.html
maybe you needz more check engine light fluid? jk i couldnt resist
check the code here ---> http://www.c-speedracing.com/faq/03.html
i pulled a code 67
Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
what exactly does that mean? I'm using a 2.5 jdm cat convertor...
i pulled a code 67
will the CEL 67 put the ECU into a "safe mode" or is this an error that can be ignored? I know some codes put the ECU into a safe mode, others are just for alerting there is a potential problem. obviously if its putting the ECU in safe mode it would need to be corrected for the car to run right. how can something like this be corrected?
well when check engine light lite last night, i turned around and headed home at 65mph on fwy. i didnt feel any loss of power at all so i dont think the car was running in limp mode..
Not all cel's put the car in limp mode. I think that happens with detonation and some other major malfunctions. This cel definitely won't put you in limp mode. I don't know if the high speed turn had anything to do with the CEL coming on, but the larger cat might be messing with the sensor.
okay, i guess i feel a little bit more at ease. can i reset it myself?
Remove the 7.5 radio/backup fuse in the under hood fuse box or disconnect the negative pole of the battery for a few seconds. Then reconnect, start the car, and let idle for about 10 minutes without any electrical accessories turned on.
You would know if you were in "Safe Mode" red line is ~5000rpm if I remember correctly, and the ECU runs horribly rich.
Austin
Austin
Not enought oil in da kaa will light up the little red oil can light not the check engine light.
But since it's a code 67, just remove the damned CEL bulb imo
cant you just press the reset button under the dash as well?
Disconnect the battery and then start up the kaa for 10 like it says above.
[Modified by 1107, 8:15 PM 11/1/2002]
JPP: Hard cornering COULD cause a bit of oil pressure loss/starvation no? Which, with low enough pressure to begin with could trip the VTEC oil pressure switch and through a code 22 no?
I am not really sure which of the two lights "check engine" or "low oil level" would light up first during a hard cornering causing oil starvation in the engine...Also wouldn't he had to be in VTEC mode during the turn for the VTEC oil presuure switch to trip (was he or wasn't he in VTEC that is the question).
