1995 Honda Civic DX Hatchback
I have a 95 Civic DX Hatchback up for sale with a lot of upgrades I am not interested in any trades cash only. The car is very clean inside and out and still has the factory paint which still looks good since the vehicle has always been garage kept and the engine has barely hit 5,000 miles after the rebuild. I am asking 6000 dollars for the car if you have any questions about the car I can be reached at 267-979-3760.
Motor:
H22a4 Complete Swap
Innovative Motor Mounts
Innovative Alternator Relocation Bracket
OEM Honda Headgasket
OEM Honda Timing Belt
OEM Honda Water Pump
Ngk Spark Plug Wires
Black Works Radiator w/ Two Slim Fans
Misimoto Radiator Hoses
Supertech Valves
Supertech Dual Valve Springs & Retainers
Ferrea Bronze Valve Guides
Skunk2 Stage
Skunk2 Pro Series Intake Manifold
Bbk 70mm Throttle Body
AEM 3 Inch Cold Air Intake
Hondata Intake Manifold Gasket
Aem Fuel Rail
Fuel Pressure Regulator and Gauge
Tri-Y Big Tube Headers
3 Inch Exhaust
3 Inch Vibrant Muffler
ACT 6 Puck Sprung Clutch
Act Heavy Duty Pressure Plate
Fidanza Lightweight Flywheel
Chipped P28 Ecu on Base Map
Interior:
Jdm Eg6 Front and Rear Seats
Jdm Eg6 Bronze Windows
Jdm Eg6 Center Console
Jdm Eg6 Cluster
Jdm Eg6 Steering Wheel
Jdm Eg6 Coin Pocket
Exterior:
Jdm Eg6 Headlights
Jdm Eg6 Corner Lights
VIS Carbon Fiber Hood
VIS Carbon Fiber Hatch
VIS Carbon Fiber Duckbill
Acura Integra Front and Rear Spindles
Brembro Blank Rotors
Hawk Performance Brake Pads
Koni Yellow 5 Way Adjustable Shocks
Ground Control Coilover
Skunk2 Front and Rear Camber Kit
Function 7 Rear Lower Control Arms
ASR Rear Subframe Brace
Motor:
H22a4 Complete Swap
Supertech Valves
Skunk2 Stage
Aem Fuel Rail
3 Inch Exhaust
Interior:
Jdm Eg6 Cluster
Jdm Eg6 Coin Pocket
Exterior:
Jdm Eg6 Headlights
i_need_a_honda
Sep 24, 2011 06:35 PM
