2006 Odyssey Sliding Door Problem
The drivers side sliding door is not functioning properly.
I can open it using the automatic features but it closes right away.
If I turn off the sliding door switch on the dash I cannot open this door manually. The passenger's side sliding door WILL open manually.
I would like to do the reset but the procedure I found on-line says to turn OFF the switch on the dash, remove fuse 7, start the engine......
I'm confused because fuse 7 (driver's side fuse panel) is labeled as "Back Up". It is a 7.5 A fuse. Is this the correct fuse?
Also I am unable to manually cycle the door because the door will not open with the switch off.
Any suggestion will be greatly apprerciated.
adamk387
May 19, 2013 06:14 PM
Ski_Bum
Apr 1, 2009 03:18 PM
