Speed sensor (vss) signal B18c
Hi, I need some technical help with the vss function. If the ecu dont see the signal of the vss the fuel/ignition map can be affected (go rich)? I remove the oem cluster in my road race EF and obvious get code 17 vss. In the hondata s300 parameters I change the vtec window to 0mph and works fine but I dont see any option to disable the vss. Now is very rich at wot and have like fuel cuts at low rpms. The ecu (fuel/ignition map) always need the vss signal to work correctly? Thanks for the help
nenacivic23
Aug 30, 2004 03:18 PM
