Motor mounts
Old Sep 22, 2014 | 07:28 PM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Motor mounts
I have a 1990 crx sir that was converted to lhd, i bought it with the conversion. I am now in the process of doing an ls/ vtec build and was wondering do i need the rhd or lhd mounts? I heard i can use the usdm mounts, but then i read that the frames are different so i cant use usdm. I would like a set of hasport or innovative but I want to make sure bedore purchasing.
Old Sep 23, 2014 | 06:26 AM
sodaZC's Avatar
Default Re: Motor mounts
Converted FROM RHD > LHD the whole front clip should be LHD... USDM LS mounts should work. Assuming you are talking about your "CRX siR ls/vtec turbo" in your signature.
Old Sep 25, 2014 | 12:49 PM
Hasport's Avatar
so your car was a rhd car that came originally equipped with a b16?
Old Sep 26, 2014 | 03:02 AM
Freemananana's Avatar
If it is the SiR it should be set up with mounts that will accept a B-series.
Old Sep 26, 2014 | 12:41 PM
Yes
Old Sep 29, 2014 | 09:40 AM
Hasport's Avatar
the DA1LH mount will work for the timing side and the DARR will work for the rear mount. unfortunately we do not have a transmission mount at this time
Old Sep 29, 2014 | 01:40 PM
Spaceballsthelunchbox's Avatar
No Big Whoop
I have now read everything there is to read about a CRX.
If it is indeed a genuine SiR, it is already made for a B series engine and therefore no need to buy mounts. Converting RHD to LHD does not necessarily involve changing the location of engine mounts.
If the whole front clip was swapped with a USDM CRX then all you need is plain old Hasport D to B series mounts since you would treat it like a regular CRX. But why on earth would anyone do that?
Old Sep 30, 2014 | 11:31 AM
lol..I bought the car like this. Reason being is that RHD cars are banned in my province, but now it's legal to drive since the conversion. The front clip was not swapped and it and it is indeed a genuine SiR.
Anyways, thanks for the help!
Old Sep 30, 2014 | 11:54 AM
.Grimace's Avatar
footwork mastery
Easy enough then
Old Oct 1, 2014 | 06:54 AM
Junaid K's Avatar
I'm a little concerned after reading this. I bought a set of Innovate
mounts for my RHD 1991 CRX ED9, for a b series conversion with hydro
box.
Can anybody confirm that these mounts are correct for my RHD car, & if
there is in fact a different kit for a LHD & RHD CRX?
Old Oct 1, 2014 | 10:56 AM
No Big Whoop
It's not the RHD or LHD that makes a difference when it comes to engine mounts. ONLY the CRX SiR either JDM or EDM is made for the B series and does not need custom mounts. Any other CRX whether JDM, USDM, EDM RHD or LHD that came with a D series engine originally needs D to B series aftermarket engine mounts.
Not all JDM CRXs were SiR.
Old Oct 1, 2014 | 01:37 PM
Hasport's Avatar
box.
those will not work with a RHD car that came equipped with a b-series
if your car had a d-series from the factory then they will work
Old Oct 2, 2014 | 12:32 AM
Junaid K's Avatar
Yes, my car had a D16a9 originally, & a B20 by the previous owner.
I bought it without an engine or box. Dropping in a B18cR with N3E
box, so these mounts should work as I purchased them as a set for
a CRX with a B-series engine & hydro box conversion. I have the
Hasport cable actuator to operate the hydro box.
Old Oct 2, 2014 | 04:51 AM
So why are there special mounts for a RHD B series crx/civic?
Innovative Mounts Steel Engine Mount Kit for RHD (B-Series 88-91 Civic & 88-91 CRX) | Hybrid Racing
And then some different one's for a B series non-rhd crx/civic?
88-91 Civic/CRX B-Series Mount Kit
Is it just me or are they different?
Old Oct 2, 2014 | 10:03 AM
No Big Whoop
Don't get confused.
The innovative mounts are aftermarket mounts to replace the stock JDM mounts for B series equipped Civic/CRX SiR (EF8 chassis). They mention the RHD stuff because most, if not all, of the SiRs we get here come from Japan with the RHD. Also to keep ED* people from ordering those mounts which would ONLY fit a true JDM EF8 SiR CRX.
The second link is a "conversion" kit to mount a B series engine in a D series equipped CRX. (ED* CRX)
RHD and LHD have NOTHING to do with the engine mounts. The engine is not relocated just because the steering is on the right or left side of the car. This is all about the Chassis you have and which engine your car came with originally.
I am done with this thread
Old Oct 2, 2014 | 10:30 AM
Don't get confused.
I gotcha..thanks. Guess I would have to order the RHD one's since my car is a real SiR converted to LHD..that's what I wasn't sure about, but now I am
Old Oct 4, 2014 | 09:42 AM
'92 HatchGuy's Avatar
I had good results with just inserts from Energy Suspension in 92-95 Civic. So I'm trying to track down the correct inserts for my current project (JDM CRX Sir B16 RHD). Can anyone tell me which kit would fit my mounts? It can be either Energy Suspension or Prothane. What i found is front and rear mounts have same part number as 91-93 Integra LS so Energy kit #16.1109 should fit, but I also want the left and right (upper) mount inserts as well. Those are Prothane #8-510 and 8-511 but I'm not 100% sure they will fit..
CRXDRU
17
Dec 1, 2012 05:30 AM
FutureCivic
Jan 29, 2007 04:25 PM
jdmrhdcrx
Feb 14, 2006 09:11 PM
civicSIracer96
10
Jul 13, 2004 04:55 PM
chirp2hrd
Apr 17, 2003 07:42 PM
