Cleaning out garage sale! B Series, Aeromotive, AEM, ECU, Rywire, Throttle Body
Old Sep 22, 2014 | 04:05 PM
m!ke's Avatar
Default Cleaning out garage sale! B Series, Aeromotive, AEM, ECU, Rywire, Throttle Body
Hello, All prices do not include shipping or paypal fees. Located in Bucks County PA if you would like to pick up locally.
JDM Type R ECU. 96-97 spec. OBD2A. P73. SOLD
96-97 spec JDM ITR throttle body with map and throttle position sensor. Perfect working condition. SOLD
Defi Blue Racer Temp Gauge. Brand new in the box. Has everything included.
$120
Fuel Lab -6 fuel filter. Brand new with mounting bracket.
$80
Integra timing belt mount. SOLD
Integra fuel rail. No regulator.
$20
DC Sports rear tie bar for EK, 96-00 Civic.
$40
OEM Honda alternator. OBD2. From a 99 Civic Si with 64k. SOLD
OEM Honda starter from 99 Civic Si. Works great. SOLD
B16A2 IAC Valve. SOLD
Brand new never been opened 99-00 Si e-brake cables. Both left and right. Will work on all EK's with rear disc and I believe integras and egs too but may not be perfect on them. SOLD
EK gauge bezel with 2 spots for gauges. Not sure of the brand. Comes with a mounting bracket. SOLD
Stock motor mounts for B and D series EK.
$30
99-00 Civic Si throttle cable.
$15
Rywire chipped OBD1 PO6 ECU with ITR basemap. VTEC at 5600 and fuel cut at 8500.
$160
ITR aluminum transmission brace/flywheel shield. SOLD
Brand new gsr upper rad hose.
$10
Blackworks oil cap. Brand new just no packaging. SOLD
AEM boost solenoid. New. Still has box and instructions.
$80
JDM ITR thermostat and housing.
$20
B Series spark plug cover. SOLD
Blackworks short shifter for B and D Series. Comes with boot and mounting plate. SOLD
JDM ITR 96-97 uncut engine harness.
$60
Thanks for looking. If you have any questions please post or send me a PM.
Old Sep 24, 2014 | 04:22 PM
m!ke's Avatar
Default Re: Cleaning out garage sale! B Series, Aeromotive, AEM, ECU, Rywire, Throttle Body
itr trans brace, short shifter, oil cap, spark plug cover, and 96-97 spec itr obd2a ecu are all sold
Old Oct 4, 2014 | 06:56 AM
m!ke's Avatar
bump
Old Oct 9, 2014 | 04:23 PM
m!ke's Avatar
fuel rail and for sold
Old Oct 30, 2014 | 07:16 PM
m!ke's Avatar
bump
Old Nov 29, 2014 | 01:14 PM
m!ke's Avatar
bump
Old Jan 4, 2015 | 10:19 AM
m!ke's Avatar
ebrake cables and gauge bezel are sold!
Old Jan 16, 2015 | 04:01 PM
m!ke's Avatar
itr throttle body, alternator, and starter sold
Old Jan 18, 2015 | 05:03 AM
B18PwdCivic's Avatar
u don't happen to have the water cross over tube do u? the one that comes from water pump housing to thermostat housing on back of block....if so pm me
Old Jan 25, 2015 | 07:34 AM
m!ke's Avatar
bump
vsmhatched
Oct 3, 2009 09:22 PM
purple98ek
Oct 22, 2007 05:59 PM
