Open D/P at the track, will the tune lean out much?
Old Sep 21, 2014 | 09:48 PM
Vagitarian's Avatar
Default Open D/P at the track, will the tune lean out much?
Hey guys, I am looking to get a good pass at the track and see what all this setup can push mph wise in the 1/4 mile. I street tuned it with a 3" turbo back exhaust, no cat and a flowthrough muffler. My afr's are about 11.2 - 11.4:1 at full boost but if i want to drop the middle section of my exhaust off at the track to run open dp, then I also lose my 02 wastegate bung as its in that section
So I will no longer have a display of accurate afr while going down the track.
Will the tune be affected greatly? Im thining because my street exhaust is very free flowing and tuned slightly lean I may still be in the safe zone unless there is a chance it would affect it more than I think it may
Old Sep 22, 2014 | 02:54 AM
V-SPEC 1's Avatar
With that a/f at full boost with said good flowing exhaust, u should b fine taking ur Dp at the track and still have a safe tune.
Old Sep 22, 2014 | 01:50 PM
Vagitarian's Avatar
Default Re: Open D/P at the track, will the tune lean out much?
ya I figured the exhaust already being straight through, just full length it may not be a huge difference
Old Sep 22, 2014 | 02:55 PM
gabocastano's Avatar
Just to be safe put a gallon or 2 of higher octane fuel when in the track.
Old Sep 22, 2014 | 03:54 PM
wantboost's Avatar
Who is Mr Robot?
Depending on how much backpressure your full exhaust causes (even the best straight through exhausts can have up to 2psi) you might see the car lean out about half a point depending on the weather.
you'd still be well within the "safe" zone but like suggested above doing something to bump octane a couple points can't hurt. if you have something like water/meth injection then set it to reach full flow sooner and maybe inject a tad bit more.
Old Sep 22, 2014 | 04:08 PM
blackeg's Avatar
this is exactly what i used to notice going from full exhaust to open header (ecutout at the end of the downpipe)
Old Sep 22, 2014 | 06:04 PM
Vagitarian's Avatar
Well since from what ive read on here and from some searching ALL say the car will lean out slightly, I will simply burn a new "open d/p" tune and add a slight ammount of fuel. I like the safety of 11.5:1 especially when there is no gauge to watch!
Old Sep 23, 2014 | 06:18 AM
wantboost's Avatar
Who is Mr Robot?
You should be fine.
Old Sep 24, 2014 | 07:37 PM
marc59's Avatar
You can also hook your af gauge to your map sensor signal wire...ran my turbo gsr hatch that way for 2 years and tuned it that way as well
Old Sep 24, 2014 | 09:33 PM
eg:R's Avatar
What will this do? will it read the a/f more Accurate ?
Old Sep 25, 2014 | 12:30 AM
m4xwellmurd3r's Avatar
Nope. What thatll do is read map vacuum/pressure as an afr number. No idea why you would want to do that since the numbers would be useless
Old Sep 25, 2014 | 12:49 PM
wantboost's Avatar
Who is Mr Robot?
That makes absolutely no sense whatsoever
It would just read boost pressure as an afr value that would have nothing to do with how the motor is running.
Old Sep 25, 2014 | 12:53 PM
boostjunkie757's Avatar
pretty sure he was only referencing where he had pulled the power source for the sensor...not where it was actually pulling its reading from to display results.
Old Sep 25, 2014 | 05:19 PM
No he clearly states he hooked his gauge to the map sensor SIGNAL wire. As in the map sensor output. Not the power wire, which wouldnt make any sense anyways since the afr gauge needs to be connected to the o2 sensor wire
Old Sep 25, 2014 | 07:26 PM
wantboost's Avatar
Who is Mr Robot?
The value displayed by the wideband would then be the same regardless of rpm and how the motor is actually running.
15psi would show the same value on the wideband whether you make it at 2,000rpm or 9,000rpm.
Totally stupid idea, all you're doing is displaying boost pressure converted to lambda which has no role or purpose in monitoring engine operating conditions.
Old Sep 26, 2014 | 05:22 AM
that was about to be my next comment, but i couldnt have imagined doing it that way since youd probably have extra wiring laying around which wouldnt exactly be good, what kinda recipe for disaster that would make...unless he isnt running an o2, which in that case you couldnt run an afr anyway...im still trying to make sense out of how he got an air fuel ratio reading out of a manifold absolute pressure sensor.
jdm-ek-si
Oct 7, 2009 12:18 PM
I AM WEASEL
72
May 7, 2008 10:24 PM
Scotty Dosent Know
Aug 31, 2007 01:24 PM
D-meet07
May 5, 2007 08:00 AM
kartman
Jan 24, 2007 11:09 AM
