96 civic AC trouble shoot
hello i have a 96 civic dx with a 2000 d16y8 swap. since i got the car the ac never worked these are the problems that i know so far:
-under the hood
ac fan doesn't turn on at all(was checked with gadget and it turns on remotely)
compressor doesn't turn on at all(same thing on top)
pressure switch bypassed it to force clutch to engage, nothing happened(pretty sure it works tho)
fuse box all fuses work and have been checked
since the compressor clutch doesn't engage the system wont take frion
i bypassed the pressure switch with cotter pin to try to engage the clutch, nothing happened.
i vacuumed out the ac lines noting.
-in the car
when ignition turned on ac doesn't .
fan doesn't engage even in the on position but radiator does.
all lights turn on the ac dash except for the ac button,
i put it on each number nothing turns on.
blower fan doesnt turn on either resistor was changed
fuses on the inside seem top be in order
seems like ac isnt getting power or something
ill post pics/create a new thread of the system if this information is too vague let me know anything
is there anything i missed ive been trying my hardest to get it to work but i hit a brick wall, anything will help thank you.
-under the hood
-in the car
Single-Cam
16
Feb 10, 2016 07:23 PM
new_ek_owner23
16
Sep 26, 2014 06:35 AM
