Crower Stage 3 cam??
does anyone have exsperience with this cam?? thsi is for the sohc vtec motor, i was on www.nipponpower.com and the cam is $340 shipped, but it says that you need alot of head work to use this cam..
now does that just mean springs,retainers,valves, and some port work??
i have a fully built head filled with ferrea goodies, and was wondering what the gains on this cam would be.. it says that it will make power up to 8500k+
if any one has exsperience with this cam, let me know
Brian
Brian
Actually here lately every day i have been hitting about 18-19psi for the last month!!! if it blows i dont care, i am in the process of building another motor with sleeved any way!!!..
and no BIG WORM it is a dual cam!!!!!
SOHC ALL THE WAY......
crower makes a cam for turbo/super charged applications go to http://www.crower.com/cat/import/honda/camshafts.shtml
and check out the 63441T not as aggressive as the stage 3 but still an alternative just depends on what you want..I'm running it in my all motor Y8 and it really runs good, I think im going to get the other stage 2 or 3 soon I need more power....
but with you running 16+ PSI will that cam be too much? I dont know too much about turbo but for some reason I thought too much of a cam can hinder performance...
If you do, however, would be building another SOHC or swap?
Please say SOHC.
What are your quarter times with your current setup?
chadalac1712
May 10, 2007 06:43 AM
RACING INTEGRATION
Mar 19, 2003 04:40 AM
