b18c jdm type r OBD2A Connector Help
Old Sep 20, 2014 | 04:03 AM
gennc's Avatar
Default b18c jdm type r OBD2A Connector Help
I need help for these 3 connectors
where to connect these 2 connectors
are these driver side shock tower or passenger side connectors if are why they are closed?
and this in connector C in ecu plug C17 ALTF where to connect this connector
Old Sep 21, 2014 | 09:42 AM
gennc's Avatar
Default Re: b18c jdm type r OBD2A Connector Help
bump
Old Sep 21, 2014 | 01:44 PM
nub's Avatar
nub
The first 2 connectors are junction plugs. The caps stay in place and dont plug into anything.
The third plug you're calling ALTF is the VSS plug.
Old Sep 22, 2014 | 09:56 AM
Rtype16's Avatar
Correct the first 2 are junctions and do not need to be plugged in. If the connector labeled AltF is truly Altf than that gets plugged into the alternator.
Old Sep 22, 2014 | 02:26 PM
gennc's Avatar
thank you for your help
i recheck and these 2 first connectors are dead end plug connector for wiring resistor box
and for the third plug is VSS
spaazm
Apr 11, 2012 09:31 PM
NZDelsoldude
16
Jan 15, 2007 04:04 PM
ej8slim
Jan 21, 2006 06:31 AM
Nameless RB26
Oct 13, 2002 10:56 PM
